Upper cabinet with overlay bottom and finished end not constructed properly
I need an upper cabinet with a bottom valance, an overlaid bottom and a finished end on one side, but the construction that results with the overlay bottom and finished end options checked results in a finished end that is not long enough (doesn't follow the valance) and it interferes/intersects with the bottom panel. It's easy to reproduce by dropping in a default single door upper, adding a bottom valance, selecting overlay bottom and checking a finished end on one side.
I feel like I'm missing something, but the incorrect construction might point to a library problem. Unless I'm wrong, I expect the bottom to overlay the non-finished side but to butt into the finished end, and to need an option for an applied panel to cover any joinery on the finished end. I can hack the panel sizes to fix the interference, but this should be an easy click-and-done scenario. I'm using Foundation 23.0609.
