When you drop a cabinet from the Product Prompts window, a warning message may pop up if something triggers the warning. There is an option to "Do not show again". After you check the box to not show the warning messages, is there a way to undo this so the warning messages pop up again? Not having the warning message is causing an issue when if you want to ignore the warning. You are forced to correct the issue before you can continue.
