Curious how you guys are handling waterfall end countertops made from solid surface materials. The stock out of the box solution from Microvellum leaves a lot to be desired as it does not address any type of mitered nosings etc. For example, if I am making a 2" thick countertop and waterfall end using 1/2" solid surface material, I am going to use the solid surface material and1.5" of substrate. I will be mitering the front of the solid surface and adding a 2" nosing to cover the front edge of the solid surface.
What has everyone done to make this in Microvellum and get accurate material reporting for the various reporting? Is it simply a case of I have to make it from scratch?
