What does Door to Cabinet gap global actually do?
Hi MV family,
I'm trying to change this gap using this global but it's not changing the hinge plate placement from the front edge of the cabinet. 37mm from front edge to the center of the bored hole for hinge plate. I've increased it from 1/8" to 3/16".
I'm using Hinge Plate BLUM Wing 0mm. I know they spec 37mm from front edge of cab to center of hole but when mounting the doors the gap is 1/16" consistent. I know we can adjust this manually but the client wants to move the hole placement to save time on adjustments.
Do I have to go into the workbook designer and try to change the hardware formulas?
Thanks in advance!
