This looks like a machining token, but I can't get it to nest after entering the correct tool. This token started appearing after a build upgrade some time ago. Is it just a drawing token? If so, why is there a tool number field? Is there a way to make it work? We have a straight line route token that we use for applying a miter to an edge, but it would be easier if I didn't have to delete this one first. I found another token named "Miter Panel Edge" but this is not named correctly because it miters a corner of a part, not an edge (unless I'm using it incorrectly). I'm just curious about these 2 tokens. As I mentioned, We have a straight line route token that we use for applying a miter to an edge, but I'm just curious about these other 2 tokens.
