When trying to create a work order and you have the different project open.
Example Every once in a while for some reason or an other I  don't close the drawing for a project to go check something on a different project. So I try to create a work order from the project I have the drawing open, But actually have a different project open which causes a ton of messages to OK
   When trying to create a work order and you have the different project open. Causes you to pretty much  click OK to an error message for each project. There has to be a better option to get rid of this message.
"Error Loading Project *** Object reference not set to" comes up for every project in your database.
