Who has moved from Component Library to Foundation Library
Who has moved from Component Library to Foundation Library and HOW did you do it?? My gosh!!
SO many things different, moved and why did that change???
While other things ... ok that's the same atleast ... LOL
Where did you start??? ... Because wow!! LOTS to change and get use to!
Looking for input as we got FL Library on SQL server and getting into the weeds now / soon.
From the COLORS being all WHITE, to the Project Wizard (Where's my hardware tab-Which found under Hardware Wizard), to Spec Group (Why not still have PL Solid, PL Grain, PG and Veneer??) to the G! table hardware is no F! table and you see the Lookup Table F from Globals .... and why change the machining of the drawer bottoms to have a goofy double notch ... was a square/rectangle too easy??
So much different and why ...
(I know there is ultimately a reason for it all ... but right now hard to see it LOL)
So .. people who have swapped over and jumped ship ... wanna give any pointers and suggestions!
(And yes I have an email in to our Account Rep ... and we know AutoCAD and CCL MV pretty good!)
How bad is the learning curve gonna be! SMH
