I recently had an issue where the nailers were dadoing into all my finished ends. The Construction Method for the Nailers were set to NONE. The Construction Method of the Finished Ends are set to Dado. I found that the Dado Machine Token is set to look at Finished End Options before it looks at the Nailer Construction Options. Thru the Library Designer I changed all the Nailer Machine Tokens to only look at the Nailer Construction option.
What is the point of having the Nailers look to the Finished Ends before going with the Construction Method I've set for the Nailers? Just curious if there is a reason. If not maybe they can change that for the next Library Update.
