We have started to produce products with curved tops and fronts (see pic). I have been utilizing the Bend token to get the front panel and the Draw Part In 2D command to do the tops. However, I can't get the necessary associated machining to work on those parts. Same with any panel that attach a miter token to.
I don't know anything about the Solid Modeling module and was wondering if it would help.
