We are wanting to redo our company template, and I have been given the job of moving some things around on that template.
I have been working at moving item numbers and dimensions to better fit our design, and have run into the following issue when trying to change the "Item Number Below Base 2D" in the workshop designer:
=IF(G!Alternate_Drawings=1,4,6
I can't figure out what that has to do with changing the distance that the item number draws in below the item itself in 2D drawings.
Can someone help with that?
