XML Import & Project Properties. GeneralContact, Contractor, etc. successfully imported?
I'm using XML importing for project estimating purposes and got XML writer utility working great, but am not able to get it to pass through the GeneralContact/Contractor/Estimator/ProjectManager/Draftsman tags to the Project Properties successfully. All others above those come in just fine, but I still have to manually fill that in. When I was using the XLS import for this same purpose, these populated no problem.
Has anybody else using XML imports ran into this issue as well, and did you find out why? My schema matches perfectly the examples found in the KB, but it still doesn't work for all the properties that aren't just text fields but a drop down from the General Contacts DB saved in the system already.
