Accessing Workbook Designer
Workbook Designer
The most commonly used method to access Workbook Designer is through Edit Design Data, by clicking on the Workbook Designer icon in the toolbar menu.
Another method to access Workbook Designer is through the Library or Project Specification Groups interfaces.
Workbook Designer can also be accessed through Database Explorer (Toolbox Setup > Options > Utilities > Database Explorer). This method will be discussed more in the Library Management section.
The last method is to open it as a stand-alone application. The Workbook Designer executable file is stored in the Program Files/Microvellum/Toolbox directory and can be copied to another location, or the Windows taskbar. The stand-alone application allows you to open files that have been saved to disk.
    • Understanding the Workbook Designer Interface
      Workbook Designer InterfaceWorkbook Designer contains more tools than the Edit Design Data interface. However, some of the advanced features of Edit Design Data are not available when working through Workbook Designer. The automatic formatting of ...
    • A Look into Workbook Designer and the Different Workbooks
      A Look into Workbook Designer and the Different Workbooks The Workbook Designer interface will be covered in more detail in a later section. However, this section will briefly cover Workbook Designer to understand the different workbooks and ...
    • Tutorial: Workbook Designer for Spec Group
      This brief article provides a guide for accessing the Workbook Designer and loading additional workbooks. With Toolbox open, click "Toolbox Setup > Project Specification Groups." Select the spec group in the left window. Click the "Open Workbook ...
    • Overview of Workbook Designer
    • Tutorial 1: Passing Prompt Information Between Workbooks (Doors)
      This tutorial shows you how to configure a subassembly to pass information between the L! workbook (local prompts), and the S! workbook (subassemblies). This example expands on the overview article "Overview: Passing Prompt Information Between ...
    • Microvellum Foundation Library Release Notes | Build 22.0520
      The following release notes apply to Microvellum Foundation Library, Build 22.0520 Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial. Additions: ...
    • The Range Hood - Add-on
      About the Library Add-on This is a “Master” Range Hood product capable of being used as is or saved back to the library numerous times in unlimited number of different combinations.  This Library Add-on is compatible with the Foundation Library. This ...
    • Toolbox Release Notes | Build 22.1.0406.641
      The following Release Notes apply to Toolbox Build 22.1.0406.641 Database Management Resolutions: Resolved an issue that caused template level projects to be deleted when deleting a seemingly “empty” category (this was caused by a mix-up in the ...
    • Microvellum Foundation Library Release Notes | Build 22.0407
      The following release notes apply to Microvellum Foundation Library, Build 22.0407 Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial. Additions: ...
    • Toolbox Release Notes | Build 22.1.0325.641
      The following Release Notes apply to Toolbox Build 22.1.0325.641 Toolfile Resolutions: Resolved an issue in certain post names where the pecking number was not working. Resolved an issue in certain post names where some face 6 machining was falling ...
