Adding Lockdowel Channel Lock E3259BM To Your Legacy Microvellum Library
    • Adding Lockdowel E85040BP To Your Legacy Microvellum Library
    • Overview: Adding a New Hardware Item to the Foundation Library
      The purpose of this article is to provide an overview on the process of adding custom hardware items to your Foundation Library. The process is similar for pulls, hinges, catches, locks, latches etc. A more comprehensive tutorial on working with ...
    • Adding a New Pull in Toolbox
      Adding 3D and 2D Images for a Custom Pull To add a Custom Pull to a library, AND include a drawing, a drawing needs to be created or downloaded from an outside source, and saved in the Factory Database > Graphics > Hardware folder. To locate the ...
    • Library Update Utility
      This article provides details on the process of updating the Foundation Library through the Library Update Utility feature. To be able to use the Library Update Utility feature, your current library must be version 22.0729 or newer, and you must have ...
    • Office Furniture Library Expansion
      Office Furniture Library Expansion The Microvellum Office Furniture Library contains an in-depth collection of furniture products. This library is intended as a foundation for manufacturers to establish their own catalog. Products can be created and ...
    • Toolbox Release Notes | Build 23.1.0329.641
      Toolbox Release Notes | Build 23.1.0329.641 Processing Center Resolutions: Resolved an error in the ‘View Nesting G-Code Results’ UI when trying to view DXF’s. ‘Modify Work Order’ will no longer remove certain edge band information if editing that ...
    • Microvellum Foundation Library Release Notes | Build 23.0320
      The following release notes apply to Microvellum Foundation Library, Build 23.0320. This update includes many changes & additions to the Microvellum Closet/Wardrobe Expansion. If you have not purchased this expansion, you will not have access to ...
    • Toolbox Release Notes | Build 23.1.0313.641
      Toolbox Release Notes | Build 23.1.0313.641 Label Images Resolutions: Resolved an issue with PTP stations not flipping the face 6 WMF image correctly. WMF orientation should now match the gcode. Resolved an issue with Unified Work Order databases not ...
    • Toolbox Release Notes | Build 23.1.0222.641
      The following Release Notes apply to Toolbox Build 23.1.0222.641. Machine Tokens Resolutions: We fixed a bug affecting certain libraries that used the CONST token, which led to incorrect calculations of the distance between holes. We also fixed an ...
    • Microvellum Foundation Library Release Notes | Build 23.0210
      The following release notes apply to Microvellum Foundation Library, Build 23.0210. Additions: • Added a new global variable “Hinge Offset From Edge” to provide easier control without needing to update the finished faces subassembly. • Added a sample ...
