Auto Size Pulls are used to select the pull size based on the width or height of the drawer or door front, depending on whether they are horizontal or vertical. This setting can be set up to be automatically applied to all products within a project.
Select Project Properties:
Select the Project Wizard tab > select the Hardware tab > select the Pulls radio button.
Each of these dropdowns contains the complete list of Pull Selections found in the Globals (G) workbook. Select one, or more, of these dropdowns > select Auto Size. The Auto Size selection creates the Auto Size Pulls tab, select it.
Within the Auto Size Pulls tab, the number of pulls to be used in the particular project or job is established with the Auto Size Pull Qty dropdown. Select the number of pulls to be used in the project.
With the Auto Size Pull Qty established, the Pulls used within the project can be selected. Select the icon next to the Pull Selection box to open the Select Hardware Interface. Select the Pulls to be used as Auto Size Pulls within the project.
With Auto Size Pulls selected, the correct sized pulls are automatically added to products depending on their dimensions. If there are product dimension changes, the pull and its associated machining are automatically updated.
Available in library build 046 and newer.
