Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6
Additions
- Added Hettich Avantech YOU Drawer system to
Imperial and Metric Libraries. Learn
more.
- Added Valance Top and Bottom to 1 Door Diagonal
Corner Upper and 2 Door Pie Cut Corner Upper.
- Added a division opening calculator to the
“Divisions and Shelves” subassembly.
- Added “PullWire375SecH.DWG” for cross-section
drawings.
- Added Machining to various Carcass Subassemblies
for Applied Thick Backs w/ Screws.
- Added a DRAWLINE token for 2D Elevation Drawings
to show the Toe Kick line at finished ends (Base and Talls).
- Added Left and Right Finished Back options to
Corner Cabinets.
- Added Base and Crown molding option to
Transition Cabinets.
- Added machine tokens to Base/Tall/Upper
carcasses to enable the global “Scribe Rout” feature.
- Added Glass Shelf option for Corner, Transition,
End Diagonal, and Curved Front Cabinets.
- Added two missing door variables in the imperial database: Buyout Single Solid Wood Front, Buyout Single Solid Wood Front SM.
Improvements
- Improved lock options on Starter Products. They now look to the global variables to activate.
- Improved Toe Kick Recess variable. It is now available for the “Toe Kick Assembly for Each Box” option.
- Improved all door/drawer face frame insert subassemblies. The drawer fronts overlay the rails in a similar way as the door/drawer FF cabinet products.
- Improved Shelf Standards machine tokens to better support the “G!Machine_Origin_Base/Tall_Sides” variable.
- Improved Subassembly Opening Inserts to function in non-starter products and SMA products.
- Improved Vertical Rear Stretcher Setup option for sink cabinets.
- Improved Toe Kick Notches to accommodate the
global “Notched Toe Raise” when used in conjunction with the “Toe Kick Notch
Relief” feature.
- Improved “Solid Surface Countertop Single” so it
can now be placed on a wall instead of 3D space only.
- Improved 2D Plan Description of Products, so it now
follows all the provided options (Back Left|Back Right|Front Left|Front
Right|Center).
- Improved “Door Uplifting Hardware” subassembly
to support Grass hinges.
- Improved Door Grain Direction variables in
Double Door Talls. They now pass down to all door subassemblies.
- Improved Invisible Fastener machine tokens
within Corner Cabinets.
- Improved Starter Products to prevent subassemblies with shelf screw machining from drilling through Finished Ends.
- Improved Microvellum Reports.
Resolutions
- Resolved rotation issues for specific pulls and proper location of flush pulls. The Flush Pull prompt has been renamed Pull
Center Rotation. Added a Center Pull Rotation Column to LookUp Table. Updated
Related Pull DWG files.
- Resolved locks issue on 2 Double Door Tall and 1
Double Door Tall. Added local prompts for Upper and Base Door Lock and had subassembly look to local prompt for locks.
- Resolved 3-4 and 1-4 Sliding Doors. Added Pulls and placed them in the correct orientation. Added grain direction to each door.
Replaced door swing lines with slide direction leader lines.
- Resolved issue with pulls not showing up on
False Fronts when “Pulls on False Fronts” was active.
- Resolved Elbow Catch location issue on Base
Starter 2 Pocket Door.
- Resolved an issue inside “Carcass Sink Angled
Frame” subassembly related to the false front.
- Resolved hinge issue inside Blind Door Corner
Upper FF.
- Resolved reported issues with door overlays in certain conditions. Updated all frameless Blind Corner cabinets.
- Resolved Rout on “Upper Sloped Top Assembly”
product. “Sloped Top Blocking” now routes in the nest.
- Resolved issue where Full Tops on sink cabinets were not taking Sub Front Thickness into account.
- Resolved issue where Counter Top Finished End overhangs in Suspended Cabinets.
- Resolved a reported issue with dado notches in
Suspended Cabinets.
- Resolved issue where Grass Dynapro Drawer Slides were not taking drawer/drawer bottom thickness into account.
- Resolved an issue affecting the Upper Corner
Cabinet (Applied Back screw machining alignment).
- Resolved an issue where Right Swing hinge plates were not looking to the correct column in G!LookUpTableHinges.
- Resolved an issue where 1 and 2 Door Sink with False
Front inserts were incorrect when the Doors and False Front were inset for Base
Horizontal Starters.
- Resolved a Sink Cutout issue inside the Diagonal
Corner Sink Base product.
- Resolved an issue with Pull locations in 2D Elevation
of Pie Cut Corner Cabinets.
- Resolved an issue with the left panel and “Use
Top” option for Base/Tall/Upper Corner Filler Products.
- Resolved an issue with inset doors and drawers for “Horizontal Opening Splitter” subassembly insert.
- Resolved Invisible Fastener rotation issue by
updating “Sink Sub Front.”
- Resolved issue in right-wing solid wood doors
that caused the mid-rail X origin to be incorrect when a user changed the
Pull/Hinge stile width.
Modifications
- Modified how “Shelves with Shelf Std” interior
component subassembly calculates shelf spacing and how help text describes
references between shelves.
- Modified Base Back Grooves in sides. Now, they stop like upper when using finished top. This relates to the Saw application. The back grooves stop based on variable top thickness material changes.
- Modified Drawer Front Adjusters to reference the drawer box’s center instead of the drawer front’s center.
- Modified the Interior Component “Glass Shelves”
to no longer hide the other shelf prompts when it is selected.
- Modified intermediate stretchers to set back
when using the variable “Top_Bottom_Inset.”
- Modified the global “Scribe Rout Depth” to be visible and located in the correct category.
- Modified Pigeonhole Insert to check for L!Shelf
Row QTY and L!Division QTY prompts to determine Opening Height QTY.
Removals
- Removed the phrase “On Angle” that was being added to edgebanding names inside transition cabinets.
- Removed the orphaned global variable “Scribe
Rout Tongue Thickness.”
- Removed over 200 orphaned records from the
MicrovellumFactory.SDF database.
Related Articles
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Component Cabinet Library Release Notes | Build 50.5
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
Component Cabinet Library Release Notes | Build 50.7
The following release notes apply to Component Cabinet Library, Build 050.7 Additions Added Products: Upper Starter Horizontal FF Multi Carcass Pullout Base 1 Drawer with Pullout Pullout Base FF Upper Starter Split Height Upper Starter Split Height ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
