Component Cabinet Library Release Notes | Build 50.0
This
build of the Component Cabinet Library was an internal release.
Additions
- Added
new Shadow Line Finger Pull option.
- Added
new global variables, global LookUpTables, material pointers, and hardware
pointers to accommodate legacy closet system products and subassemblies.
- Added
Global Variables for Shadow Line feature:
- G!LookUpTablesShadowline
- G!Use
Shadow Line System w Notched Sides
- G!Shadow_Line_Type
- G!Shadow
Line Wrapped Batten Width
Improvements
- Improved
the Perfect Grain option “Split Double Width Cabinets” so that it works with
all sink products with False Fronts.
Resolutions
- Resolved an issue where Door Single Slab was adding a lock to the Hinge Door in Pie Cut
conditions.
- Resolved
2D Elevation Hinge Swing Lines for top-hinged doors.
Removals
- Removed
hard locked tool numbers from Carcass Upper Microwave.
Related Articles
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.5
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
Component Cabinet Library Release Notes | Build 50.7
The following release notes apply to Component Cabinet Library, Build 050.7 Additions Added Products: Upper Starter Horizontal FF Multi Carcass Pullout Base 1 Drawer with Pullout Pullout Base FF Upper Starter Split Height Upper Starter Split Height ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
