Component Cabinet Library Release Notes | Build 50.1
This
build of the Component Cabinet Library was an internal release.
Additions
- Added
prompt variables and lookup tables inside template Hardware workbook to support
new Toolbox hardware counting feature.
- Added
formula data to all CONST, HOLES, CAMLOCK, PLINEFROMHOLES tokens to count
hardware usage.
- Added
new library category “Appliances.” Copied Room Component appliance products into this location so we can support them inside grouped products.
- Added
two new worksheets to Template “H” (hardware) workbook: Prompts and
LookUpTables.
Removals
- Removed
all part and product Activity Tokens from all products and subassemblies.
- Removed
all Pricing/Costing variables and lookuptables from Global and Project Wizard
files.
- Removed
all Pricing/Costing Prompts and Tabs from all products.
Related Articles
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Component Cabinet Library Release Notes | Build 50.5
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
Component Cabinet Library Release Notes | Build 50.7
The following release notes apply to Component Cabinet Library, Build 050.7 Additions Added Products: Upper Starter Horizontal FF Multi Carcass Pullout Base 1 Drawer with Pullout Pullout Base FF Upper Starter Split Height Upper Starter Split Height ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
