Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions
- Added
new product to the Miscellaneous category: Trolley.
- Added
three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report.
- Added
two new interior component shelf subassemblies: Adjustable Shelves EQ and Fixed
Shelves EQ. Using these allows the user to have an unlimited number of shelves per opening.
- Added
additional template global files to change and demonstrate the different
construction styles quickly.
- Added
option to Add Rendering Lights and a polyline to represent a floor.
- Added
a basic Island Grouped Product for demonstration purposes.
- Added
Hardware Edge Array feature. Limited to only regular box cabinet parts.
- Added
Prompts and LookUpTables worksheets to H, M, E spec group files (for future use).
- Added
new “Formula” materials (supported by Toolbox now).
Improvements
- Improved
the Wall Room Component Product.
- Improved
the Prompt “Cabinet Body Edgeband Thickness” to support local product EB
changes.
- Improved
Library settings so all are set to use Annotative Scaling. Updated default
drawing template to assume annotative.
- Improved
Drawer Depth calculations inside starter cabinets to now match regular
non-starter cabinet products.
Resolutions
- Resolved
minor issues with Counter Top Cores w Toggle Bolts products.
- Resolved
setback issue at Face Frame cabinets in “Rollouts” subassembly insert.
Modifications
- Modified
radius at the inside corner of the Pie Cut Corner Cabinets. It is now 20mm. This can be disabled in the subassembly.
- Modified
all drawer slide hardware to “Skip Spreadsheet Sync.”
- Moved
all global lookup tables to their worksheet.
Removals
- Removed
over 500 rows of hardware from Hardware Workbook.
Related Articles
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Component Cabinet Library Release Notes | Build 50.5
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
Component Cabinet Library Release Notes | Build 50.7
The following release notes apply to Component Cabinet Library, Build 050.7 Additions Added Products: Upper Starter Horizontal FF Multi Carcass Pullout Base 1 Drawer with Pullout Pullout Base FF Upper Starter Split Height Upper Starter Split Height ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
