Added
back the product â1 Door Base Curved Front FF.â
Added
rear shelf support notch to Adj & Fixed Shelves subassembly.
Added
âMV Material Costing Report.â
Improvements
Improved
Island Grouped Product.
Improved
ALL costing reports.
Improved
MVTokensClipboard.xls. Will now include tokens that are more dynamic and available on all four edges. Supports Screws, Dowels, Camlock, Dado, and
Invisible Fasteners.
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
