Component Cabinet Library Release Notes | Build 50.4
This
build of the Component Cabinet Library was an internal release)
Additions
- Added three new job-costing reports and updated
activity stations to align.
- Added missing room component Window and Door
subassemblies inside the metric database.
- Added new global variable “Show_2D_Elv_Solid_Wood_Door_Parts.”
- Added “Rollout Space 3_4” to the hardware
inventory.
Improvements
- Improved Mater Cut Report – Sorted by Processing.
- Improved several Face Frame Door and Drawer
inserts.
- Improved the dwg block “3D_Hinge FF BLUM INSET Cam
Adapter Plate.DWG.” This block was causing significant MV slowdowns during
product redraws.
- Improved Face Frame hinges at starter product
openings.
- Improved ALL hardware graphics dwg files.
- Improved Pie Cut Corner Carcass Subassemblies to
now support different depth and width values when using a Polyline for the pie
cut machining.
- Improved Shoe Shelf Subassembly.
- Improved “3 Section Suspended Open Cabinet FF,” so openings start equal without using the opening calculator.
- Improved all Grass Tiomos hinge plate dwg blocks to rotate in the correct direction.
Resolutions
- Resolved issue with opening depth and fourth drawer
Z origin error for several Face Frame Door and Drawer inserts.
- Resolved an issue where the Drawer Front Calculator in “5 Drawer Base FF,” was incorrectly using a frameless formula.
- Resolved an issue with FE Text Style link to global.
- Resolved a 3D rep issue with Lockdowel machining by updating the Router Bit.
- Resolved issues with the second window and second door option for wall room component product.
- Resolved an issue with “Vertical Opening Splitter”
to correct an issue with Door heights at inset conditions.
Modifications
- Modified the Saw tool numbers to 60 inside IPP tool files.
- Modified “Door Uplifting Hardware” subassembly to support the valance option at Aventos HF Bi-Fold Doors.
- Modified FE Slab option to no longer have toe kick notches behind face frame stiles that extend to the floor.
- Modified Invisible Fastener machine tokens to better support connections to insertion machines (Lockdowel).
Removals
- Purged unnecessary data to improve library performance.
Related Articles
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Component Cabinet Library Release Notes | Build 50.5
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
