Component Cabinet Library Release Notes | Build 50.5
We
are excited to announce the updates for the Component Cabinet Library (Build
050.5). Below is a list of the new features and enhancements
we've recently made to improve your experience with this product library.
Additions
- Added the ability for Blind
Panels to receive hinge plate machining on face 5.
- Added "Rollouts" to
the global "List Interior Components."
Improvements
- Improved the Filler Elevation
Tokens to follow the dimension style.
- Improved multiple aspects of
the 2D elevation drawing of Face Frames. This specifically targets the
global variable "G!Show_2D_Elv_Face_Frame_Parts". By unchecking
this option, you can achieve an accurate 2D representation of face frames
without the joint lines. This provides a cleaner 2D drawing.
Resolutions
- Resolved issues with National
Deadbolt Locks.
Modifications
- Modified "Single Drawer
Stretcher" subassembly. Edgebanding material name was hard locked to
"None."
- Modified all Part Label reports
- Modified the 2D elev door swing
line token for flip-up door conditions (will now display correctly when in
a nested Subassembly)
- Modified the Glass Insert
Subassembly and removed hard locked imperial values and tool numbers.
Removals
- Removed the legacy global
variable "Use_Finger_Pull_Rails_On_Drawer_Stretchers."
Related Articles
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Component Cabinet Library Release Notes | Build 50.7
The following release notes apply to Component Cabinet Library, Build 050.7 Additions Added Products: Upper Starter Horizontal FF Multi Carcass Pullout Base 1 Drawer with Pullout Pullout Base FF Upper Starter Split Height Upper Starter Split Height ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
