Component Cabinet Library (USA, CAN) | Previous Releases
Build 49.1
New Features:
Added new Drawer Systems Grass Integra and Vionaro. This includes all-new 3D and 2D drawing graphics. The Vionaro uses integrated Grass Dynapro slides and locking devices.
Added new Grass Drawer Slide options: Dynapro, Dynapro Tipmatic, Dynapro Heavy Duty, Dynapro Heavy Duty Tipmatic, Elite Plus Undermount, Maxcess Undermount. This includes all-new 3D and 2D drawing graphics.
Added new Grass Tiomos hinge system (regular and institutional). This includes all-new 3D drawing graphics,
Institutional / Regular
Full Overlay / Half Overlay / Inset
Hinge angles: 95 deg Thick, 110 deg, 120 deg, 160 deg,
Dowel Types: Impresso 42_45 / Dowelled 42 / Dowelled 45 / Screw-On 42 / Screw-On 45
Plate Height Types: Worm Gear / Screw, Plate Fixing Points: 4 Point Fixing / 3 Point Fixing / 2 Point Fixing
Plate Screw Type: Expanding Dowel / Euro Screw / Euro Screw Mounted / Wood Screw
Corrections, changes, and improvements made:
Updated Drawer Systems Grass ZBox and Zargen to better match other drawer systems in the library
Added the missing material "EB Non Original Edge" to the Drawing Only material category
Updates to Transition and End Diagonal Shelf subassemblies
Corrected issue with 2 Drawer Base w Range Top product
The global variable "Top Pre Drill Base Top" will no longer activate this feature in Tall products.
Corrected a reported issue inside the Carcass Sink Angled Frame subassembly
Edits made to Base/Tall/Upper Scribe Filler Products: Removed 2D elev Draw Tokens, changed default scribe amount to 0.5" (13mm)
Changed the metric global variable Accuracy to "2" instead of "0".
Updated Door and Drawer subassembly inserts
Updated/Added Reports:
Work Order Summary - Project Properties(params)
Work Order Summary - Project Properties(events)
Product Shipping Manifest - Project Properties
Parts Select P2P Report
Parts Select Processing
Parts by Processing Station
Parts Not Optimized Report
Removed "Additional Hinge Settings" folder from global variables. Added "Hinge Options", "Blum Hinge Options", and "Grass Hinge Options" folders.
Updated global variables:
Door Overlay Institutional
Door Overlay Institutional Half
List Hinge Selections
List Hinge Selections Diagonal
Hinge Institutional Calc
Removed global variables:
Draw Grass Drawer Runners
Mepla_File_Drw_Min_Height
Mepla_Top_Gap
Mepla_Bottom_Gap
Mepla_Bottom_Gap_at_Bottom
Hinge_Plate_Inset_Mepla
Mepla_Dynamic_Thick_Material
Draw_Mepla_Dynamic
Mepla_File_Slide
Bore_Mepla_Alfit_Bottom_Holes
Bore_Mepla_Alfit_Back_Holes
Bore_Mepla_Alfit_Fixing_Bracket
Draw_Mepla_Alfit
List_Hinge_Angle_Mepla
Hinge_Angle_Mepla
Use_Integra_Size_53mm
Use_Integra_Size_85mm
Use_Integra_Size_117mm
Use_Integra_Size_149mm
Added new global variables:
Draw Grass Drawer Runners 3D Model
Draw Grass Drawer Runners 2D Sections
List Hinge Angle Grass Nexis
List Hinge Angle Grass Tiomos
Grass Hinge Dowel Type
Grass Hinge Institutional Dowel Type
Grass Hinge Institutional Color
Grass Tiomos HingePlate Height Type
Grass Tiomos HingePlate Fixing Points
Grass Tiomos HingePlate Screw Type
Grass Tiomos HingePlate Name Calc
Wood Screw Pilot Hole Diameter
Wood Screw Pilot Hole Depth
Removed Mepla hinges and generic GRASS hinges from global table LookUpTableHinges
Removed Mepla references from global table LookUpTableHingePlates
Removed "Mepla Alfit" & "Mepla Dynamic Undermount" from the global table LookUpTableSystemDrawerSlide
Removed "Mepla Integra Rollout" from global table LookUpTableSystemRollout
Removed material pointers:
Drawer_Box_Mepla_Integra_Back
Drawer_Box_Mepla_Integra_Bottom
Added material pointers:
Drawer_Box_Grass_13
Drawer_Box_Grass_16
Drawer_Box_Grass_19
Removed all 2D & 3D "Hinge MEPLA" dwg files from Graphics folders
Build 49.0
New Features - New Products:
“Upper Flip Up Cabinets Face Frame” product category added.
“Top Pocket Door Upper” framed and frameless products added
Added new drawer system hardware option Grass ZBox
Upper Microwave cabinets now have a new Angled Side feature
Added new category of countertop core products. These come in a variety of different configurations and have options such as Toggle Bolt connectors, Male/Female Mason Miters, and regular Miters. Profile edge options, back/side splashes, build-up parts not supported at this time.
Updated Decorative Panel product
Updated Dovetail Drawer machining
Improvements made to Framed and Frameless Starters and Splitters to show openings in 2D Elevations.
Added Top Door Height and Bottom Door Height Prompts to 1&2 Double Door Talls rather than controlling Door Heights by Fixed Shelf Height
Fixed issue with Corner Cabs not turning on Lazy Susan in the products if Lazy Susan globals were set to a size.
Added Option to machine Toe Kick Notch on Applied FEs in Extruded Die Wall 2.5.
Fixed issue with Horizontal Splitter not working with 1 Drawer and G!Drawer_Box_Fixed_Location.
“Pocket” option added to Uplifting Type Options in global. Flip Up Door Subassembly Insert and corresponding Hardware added to Door Uplifting Hardware Sub.
A few minor fixes made to Base, Tall, and Upper 2 Pocket Door Sub Inserts.
Fixes made to Door Uplifting Hardware Sub to better support Hinge with Flap Stay, Inset Door condition, and Face Frame Conditions.
Flip Up Door added to Face Frame Product Starter Bay Options
Fixed Issue with Back Inset calculating to Nailer Thickness when nailer positions are Inside Back and Full Applied Back, and issue with thick back inset when Full Applied Back. Added new global settings and updated Local Product Back Inset Prompts. Add new globals:
Base Back Inset Full Applied No Outside Nailer
Base Thick Back Inset Full Applied
Tall Back Inset Full Applied No Outside Nailer
Tall Thick Back Inset Full Applied
Upper Back Inset Full Applied No Outside Nailer
Upper Thick Back Inset Full Applied
Resolved issue with Upper Wide Span Bottom Edging not switching when Bottom Material switches by adding Cabinet_Body_Edgeband_Wide_Span_Material_Name prompt to local product and subassemblies etc.
Corrected Diagonal Corner Face Frame Cabinet Top, Bottom and Shelves that were not Chamfering at the correct location.
Added Diagonal, Pie Cut, and End Diagonal Face Frame 2D Plan Tokens
Added Missing Horizontal Gap prompt to Vertical Starter FF products in order to fix name error when Reveal Control is checked.
Added data to further support Drill Through at Bay Divisions for Adj Shelf Holes, Dowel Holes for Fixed Shelves, Dust Panels, Drw Stretchers, and Drawer Slide Holes. Includes new global variables, local starter product prompts and subassembly prompts.
Added data to further support Offset Dowel Holes at Bay Divisions on Dowel Holes for Fixed Shelves, Dust Panels, Drw Stretchers. Includes new global variables, local starter product prompts and subassembly prompts.
Double Drawer Division first row Division within Sub was getting Face 6 machining. So changed the machine point to be 2M instead of 1 when Use Double Division was on in order to get Face 5 machining on both.
Fixed issue where some Adjustable or Fixed Shelf and Division Material Local Product prompts were hiding when they should be visible.
Removed Subassemblies: Drawer Grass Unigrass, Drawer Grass Unigrass File
Grass File Drw Min Height
Use Grass Unigrass 43mm
Use Grass Unigrass 85mm
Use Grass Unigrass 117mm
Use Grass Unigrass 149mm
Use Grass Unigrass 213mm
Grass File Slide
Grass File Rail
Bore Grass Fixing Bracket
Bore Unigrass Back Holes
Drw Bottom Grass Mach
Draw Grass Unigrass
Added global variables:
Grass Drill Back Holes
Grass Drawer Bottom Groove Machining
Use Grass ZBox 85mm
Use Grass ZBox 149mm
Use Grass ZBox 213mm
Grass ZBox File Slide
Grass File Rail
Grass 6100 Railing Back Clip
Added new subassembly: Drawer Grass ZBox. Updated G!List_Regular_Drawer_Systems, G!List_File_Drawer_Systems, G!LookUpTableSystemDrawer.
Added new Graphics Files for Grass ZBox.
In the Drawer Standard Wood Box File subassembly, the Front Rail, Back Rail, and Side Rails did not have a negative material and were showing up in work orders as cut parts.
Improvements made to Microwave Upper Product along with new Microwave Specific Upper Carcass. Replaced FILLET Token with PLINE in conjunction with OFFSETPOLYLINE function to account for edging. Now better supports all construction fastening types. Also added new Angled Side features.
Resolved issues when using the global option “Drawer_Box_Fixed_Location” with Face Frame drawer cabinets.
2D Elevation Grain Symbol will now only display for grained material. Also added grain symbol for cabinet backs at open conditions.
To address performance issues, replaced PARTQUANTITY(MVCP) with Panel_Qty in all formulas.
Corrected issue in Open Curved Corner cabinets when changing Curved Distance prompt
Removed 2D Plan View Door Swing for Top Hinge conditions
Corrected issue with Rear Right Corner Notch option in Base/Tall/Upper Carcass subassemblies.
Pie Cut Corner Products, Left/Right Reveal prompts correction.
Default Blum Tandem Slide option changed to Tandem 562 F Series. Will show now show the hardware in 3D.
Selecting Hanger Notch option will now always work, even though there may also be a Finished End. By default, selecting a finished end will disable the hanger notch. However, you can now override this.
Addressed issues with the global option "Hinge Tall Center Option".
SLIDE token machining on all drawers will now have correct part name filters when a drawer is rotated 180 in a product.
Added missing "Drawer_Pull" prompt to splitter subassemblies (plus several others).
Addressed issues with 2D Draw Token for Arcs in the Wall room component. Using PLINE token instead of DRAWARC token
Added Single False Front option to Vertical Starter Products
Changed the global “Default Pocketing Tool” to be 105, which is the default pocketing tool in the sample tool file.
Updated 14 different manufacturing reports
Build 48.4
Imperial Only
Added a new global variable called "Invisible Fasteners Hole Pattern". This can be set to "Auto Space" (default) which will position the holes equally spaced as before. Setting this to "Custom Space" will point the horizontal drilling pattern to a new table called "LookUpTableCustomSpacedInvisibleFasteners". From this table, any custom drilling pattern can be entered. By default, a 32mm pattern is entered in to support users with offline (non-CNC) horizontal boring machines.
Division parts behind face frame stiles will no longer have edgebanding
Drawer Division parts will now be on the appropriate layer in 2D
Addressed issue with Pulls Associating to Diagonal Bottom of upper corner cabinets.
Build 48.3
New Features:
Added Shelf Support Notch feature. Supports both 3Sidednotch or single route operations, depending on the size that’s required. Added new globals:
Shelf Support Routing
Shelf Support Routing Tool
Shelf Support Rout Width
Shelf Support Rout Length
Shelf Support Rout Depth.
Added support to allow the display of hidden lines of cabinet carcass parts in 2d Elev. Added new globals:
Hidden Carcass Elevation Layer
Hidden Drawer Part Elevation Layer
Added drawing token for a plan view of a swinging door. Added new globals:
Door Opening Plan Layer
Door Opening Angle (set to zero to disable feature)
Updated Base Counter Top Subassembly. Added a "Seam" option to the left/right edge detail conditions.
Added ability to individually turn off left or right toe kick notches via the subassembly carcass prompts.
Completed the setup for the global "Drawer Box Fixed Location" feature. Select to always have the drawer box at the same location from the bottom of the drawer front.
Added a "Generic Slab Override" option to accommodate special conditions when the Left or Right side of a cabinet requires an applied slab panel in lieu of a Solid Wood applied panel everywhere else.
The Rollouts subassembly insert will now go up to 10 rollouts.
Numerous corrections and improvements made throughout the entire library:
Updated Elias Door DSVX file to only include the Elias, Generic, and User Defined Libraries. Added some missing data for the Elias door styles.
Single Drawer Stretcher subassembly quantity did not reference Drw_Stretcher prompt correctly on some door-drawer cabinets
Corrected issue in Door Uplifting Hardware subassembly. Extra blank row on prompts worksheet preventing Library Designer from seeing formulas after row 70. Updated formulas below row 70 that needed updates.
Improvements made to Dovetail Drawers including, syncing Dovetail Machining in Rollout to enhancements made previously in the Drawers, a few other minor Dovetail and miscellaneous fixes, corrections to Tandem Undermount machining, and Widespan Bottom logic added to Drawer.
Improvements made to "Reverse View FF Draw Tokens" feature.
Updated LockDowel Invisible Fastener machining. Various edits added support for transition, curved front, and other misc details.
Made corrections to curved front products
Changed "Pull Double Pull Location" formula. Pulls will now align in the 1 Dbl 2 Single Drawer Base product.
Corrected issue with inset hinge plates not appearing in starter cabinets
Updated formulas for Drawer Front Heights in 8 Drawer Base product.
Addressed issue in Starter Cabinets when Inset Doors were selected. For the Bay 1-10 Interior Components, added formula logic to reduce the subassembly Depth and Y Origin when Inset Door is selected.
In single door subassemblies, changed the radio button prompt "Top_Hinge_SA" to a checkbox. This prevents problems with the origins of the door and hardware.
Adj Shelf Subassemblies did not reference "Banded Front and Back".
Updated Single Parts Product. Moved lookup tables to separate worksheets.
Corrected issues with 2D cross-section of pulls (locations and sizes).
Sliding Door Cabinets now reference G!Sliding_Door_Overlay for their door widths.
Addressed issue in ADA Sink Angled Frame product. Back Length and Origin.
G!Last_Const_Hole_On_32mm is now hidden as it is no longer referenced. G!Force_Last_Hole_On_32mm is now used.
Tall and Upper Face Frame cabinet sides will no longer have edgebanding on the top edge by default.
Addressed several issues within Corner Cabinet products
Added POLYLINE token for 2D representation inside the Curved Die Wall product.
Deleted the following Cam Lock global variables as they were duplicates:
G!Cam_Edge_Bore_Diameter
G!Cam_Vertical_Bore_Diameter
G!Cam_Horizontal_Face_Diameter
G!Cam_Horizontal_Face_Diameter_2
Build 48.2
Fixed drawer front pull rotation issue.
Project Wizard variables Pull Distance From Door Edge changed from 2" to 1-3/4".
Fixed thickness issue with Solid Wood Single Panel Drawer Parts
Added missing Blum Antaro hardware materials
Added missing Pullout hardware materials
Added a "Machine Blank Panel" part to all doors, drawer fronts, FE panels. This is used for the consistency of hardware association. Added new D!Use_Machine_Blank_Door_Option variable.
Added new D!Draw_Door_Assembly_Parts variable to door wizard. Pointed 3D draw tokens of all door parts to it.
Corrected an issue inside Empty Product Starter
Added support for Metric Database
Added Elias Door wizard option (separate door wizard file)
Numerous improvements to door data
Build 48.1
This build of the Component Cabinet Library was an internal release
Added formula to global "Force Second Hole 32mm From Start and End" to enable screws and dowels to appear when using "Combine Dowel and Screw Pattern".
Updated Project Wizard variable Door Type and Door Style.
Corrected circular reference issues.
Corrected issue in MDF Door w Machining. Issue with the Tombstone Style.
Corrected issues with single panel doors (plank style).
Removed the "Use Last Value" formulas from Adj & Fixed Shelf Qty prompts. This was causing the formula to be overwritten, which caused the reported value to be inaccurate.
Numerous edits & changes related to the new door data
Updated face frame draw tokens. Additional globals, draw tokens, and dim styles added. Improved support for opening dimensions at a reverse view.
Build 48.0
This build of the Component Cabinet Library was an internal release.
A complete overhaul of Door Library data. All formulas pertaining to the Door Library, Door Type, Door Style, D!LookUpTable references, and most all other variables have been changed.
Formulas inside cut parts of Solid Wood Door, Drawer Front, False Front, Applied FE Panel subassemblies no longer directly reference D! LookUpTables inside the Door wizard spreadsheet. This enables easier reading and interpretation of cut part formulas (including machine tokens).
Build 47.1
Fixed issue with perfect grain
Fixed issue with Wall room component product
Build 47.0
Numerous corrections made throughout products and subassemblies
Revisions made to drawing templates
In Door/Drawer cabinets, moved WallOffset prompt to Tab Index 5
Updated "Color Label" prompt to only include the first 4 characters of the CutParts name.
Removed overlapping defined names from "Adjustable and Fixed Shelves Corner", "Adjustable and Fixed Shelves End Diagonal" subassembly
Added Plan View Hatch pattern option to Wall product
Added new ADA Sink Angled Frame product
Corrected Upper Microwave fixed shelf depth when using applied back with nailers
Consolidated all Imperial and Metric Range Top Drawing Blocks. Room Components and library products now use the same blocks. Deleted redundant blocks. Renamed blocks with a shorter file name to avoid installation issues. All now located in \Graphics\Drawing Blocks\Appliances\Range Tops
Added "Cam Pattern" missing prompt to "Adjustable and Fixed Shelves" subassembly.
Removed "Dynamic Product Image Exploded View" option from all products. Added SW exploded view and 2nd title block to all product dynamic images.
Finished Tops and Bottoms for Base, Tall, Upper cabinets will now be on CABINET_FE layer so they are blue like doors and FE parts.
Corrected issue with Finished Panel products and Notch for Toe Kick option
Corrected issue with drafting prompts in FE panel products (Right hands)
Corrected issue in Door Single Slab. Missing 2D elevation Door Swing lines in Pie Cut cabinets
Changed Door Single Slab 2D elevation for Pull. Added formula to turn off block if pull is "None".
Added 2D Panel to Door Left/Right Slab for corner cabinet 2D drawing
Corrected Double Throw Locks that referenced the same strike plate for both locations
Corrected issue with Toe Notch Local Prompt in ADA and all No Bottom Cabs.
Small improvements made to Door Locks. Added two New globals: Lock Left Door Base, Lock Left Door Tall. Deleted global: Lock Left Door
Corrected issue with Solid Wood False Fronts when nested inside a right side face frame.
Added new global variables to provide better control of cabinet part names:
Divider Name
Division Name
Drawer Division Name
Adjustable Shelf Name
Fixed Shelf Name
Adjustable Shelf Edge Name
Fixed Shelf Edge Name
Wide Span Thick Shelf Name
Blind Panel Name
Blind Hinge Panel Name
Applied FE Name
Slab Door Name
Slab Drawer Front Name
Slab False Front Name
Drawer Box Side Name
Drawer Box Sub Front Name
Drawer Box Back Name
Drawer Box Bottom Name
Name Filter Hinges
Name Filter Pulls
Removed Global Variable "Open Finish" as it was in there twice.
Updated most all cabinet part name formulas to point to new global part name Variables. This was done to better accommodate other languages such as French.
Updated all reports and labels in both imperial and metric databases. Purged out old redundant versions.
Corrected issue with Face Frame Modifiers when using "Extended to the Floor" option.
The Door Wizard will now unhide variables when Generic Five Piece is the Door Type
Added new global variable "Finished Bottom at Valance". Turn on if you would like the Bottom of Upper cabs with Valances to be the Open Finished material at Bottom Side. Otherwise, they will be the Interior Finish Material at Bottom Side.
Apron product part sizes now reference M!Aprons_Thickness instead of M!Misc_Part_Thickness
Dovetail Drawer box Bottom Dado Parameter 8 is now referencing G!Drawer_Box_Dado_Depth instead of G!Back_Dado_Depth.
Corrected issue with Left/Right side lengths in Tall cabinets when Top Valance is used.
Corrected machining issue with "Lock Timberline Cam Vertical Right"
Changed "Shelf Bore Depth On Divisions" prompt in Divisions with Shelves Subassembly
Cabinet Sides will no longer collide with Side Face Frames when Fin_End_Left/Right is on.
Updated Invisible Fastener data to function properly with Toolbox 15.5 update.
Added Lockdowel H-Clip spring pin machine tokens
Corrected machining issues in corner cabinets when "Don't Drill Last Dowel (or Screw) Hole" is on.
Build 46.2
Face Frame Cabinet Changes:
Updated Face Frame Starter Products. Now support the "Remove Stile" & Front Corner options.
Updated Base, Tall & Upper Face Frame, Base, Tall & Upper Face Frame Haunched subassemblies to support previous line item.
Updated "2 Door Sink Base w False Front FF" product. Center Mid rail was off in X when remove left stile checked. Updated L!Opening_Mid_Point.
Updated Side Face Frame subassemblies.
Added missing prompt "Inset Door Reveal" to all Face Frame Starter Products
Changed Metric Global "Face Frame Reports Dim Suffix" to be "mm".
Updated G!Upper_Bottom_FF_Overlay
Upper Side Face Frames now have a new Use_Tall_Applied_FE_Panels sub prompt that looks out to the local if there, and logic was added to the nested Applied FE Panel name formulas to switch accordingly. Now on the panels within an upper side FF you can have a multi-panel FE as well.
Deleted Subassembly "Base FF Diagonal wmf"
Updated all subassemblies with a face frame part. All new draw tokens have been developed to take advantage of new FLATSHOT feature.
Updated dwt Drawing Templates with new dimstyles and layers needed for Face Frame drawings
Added new Global Variables: FF Dim Text Width, FF Dim Text Height, FF Horizontal Dim Offset, FF Vertical Dim Offset
Invisible Fastener Changes:
Added Jpg help images to Invisible Fasteners global variables
An adjustment was made to the construction hole layout for Invisible Fastener Tokens. This will allow Lockdowel placements to match with the Laguna LD-4 machine.
Updated G!LookUpTableInvisibleFasteners table with a new column, new rows, and some updated data.
Made edit to G!LookUpTableInvisibleFasteners to address error in CONSTRUCTIONHOLESPACING spreadsheet function. First row needs a value in column 6 & 7.
Added 3 Lockdowel Slides to G!LookUpTableSystemDrawerSlide
Added 2 Lockdowel Drawers to G!LookUpTableSystemDrawer
Added 3 new Global LookUpTables for Lockdowel Slide Hardware. LookUpTableDrwSlideLDSCU, LookUpTableDrwSlideLDSMSC45, LookUpTableDrwSlideLDSM3P45
Added global variables G!List_Invisible_Fasteners, G!Invisible_Fasteners_Drawer_Slides, G!Invisible_Fastener_Back_Retainer, G!Invisible_Fastener_Division_to_Stretcher
Numerous changes related to Lockdowel & Invisible Fastener integration
Updated FastenLink Vector locations. Offset them -4mm (half of dowel dia).
Break Fixes & Miscellaneous Changes:
Added missing hardware machine tokens for "Lockbar Ganglock Cylinder Body Timberline".
Added new Rollout Tandembox subassembly
Updated "Hidden Parts Layer" global variable to be "HiddenPartsFREEZE"
Corrected all Extruded Die Wall product's 2D plan view drawing
Updated "Divisions with Shelves" subassembly to look at global "G!Drill_Through_at_Division_for_Shelves"
Global "G!Drill_Through_at_Division_for_Shelves" now a combo box with these options: Drill Through On Right|Drill Through On Left|Drill On Both Faces
Updated "Sink Depth" prompt in sink products.
Added Accuride 2132 drawing blocks.
Fixed issue with User Defined door option. When selecting option via wizard, wrong subassembly was being used.
Updated MDF Door w Machining subs. There was a token with missing parameters for tool and compensation when a mid rail was added.
Updated Drawer Standard Wood Box (and file, rollouts). Left Side is now machine point 2M and Right Side is now machine point 1. Previously this was not possible because of the SLIDE token. Changing this prevents face 6 machining.
"Show Rear Modification Options" removed from Vertical Starter Products until further development can be made.
To speed spreadsheet performance, modified many global variable formulas to use IFERROR function.
Removed Wall End Valance & Miterfold Wall Filler from Global Variables
Updated Divisions with Shelves subassembly. Screw holes at fixed shelves will no longer happen at divisions or finished ends.
Updated Divisions with Shelves & Adjustable and Fixed Shelves subassemblies. Modified formulas in virtual routes, parameter 1. Cabinets should draw and process faster if VECTORS & PNT functions are avoided unless needed.
Replaced numerous examples of IF(ISERR( with IFERROR(0,0). See example:
BEFORE: =IF(ISERR(INDIRECT(PARENTNAME("Fixed_Shelf_Setback"))),0,INDIRECT(PARENTNAME("Fixed_Shelf_Setback")))
AFTER: =IFERROR(INDIRECT(PARENTNAME("Fixed_Shelf_Setback")),0)
Added Refrigerator subassembly to the Appliances folder
Added 2 Door Refer Enclosure Tall product to Appliance Cabinets categories. Several changes made to Carcass Tall subassembly to accommodate.
Left/Right End Dimension prompt in all cabinets is now looking to G!Finished_End_Dimensions
Corrected an issue in the D!LookUpTableExternalProfile count column that causes an issue if you put a value in the single drawing token column. Formula should update to stop counting at column BH.
Updates to the Decorative Panel product. There was an issue with the external profile if you were using a bead tool. Updated the leadins to overlap the routing instead of leading in off the panel when all 4 edges are profiled.
Updates to Grass Unigrass & Zargen drawer subassemblies. Addressed several issues.
Updates to Drawer Front Solid Wood Subassembly
Changed New Pull Wizard Variables Col K value of 1 which is hide to 0 or blank so they are visible.
Corrected Issue where Dust Panels were not turning on under certain Global Stretcher Option combinations. Specifically when stretchers were always on but needed to turn to Dust Panel on locked drawers.
Further Improvements and Fixes made to FE Tall Left Solid Wood and FE Tall Right Solid Wood Subassemblies for Multi-panel Options
Corrected issue where False Front Subassembly name formula was evaluating to Slab when it should be Solid Wood and False Front was not appearing. Updated formula to latest structure.
Updated Applied FE & Fin Back Solid Wood Subs "FE_Panel_Type_Override" Prompt Combo Box Value formulas to be latest that will build automatically from Door Wizard as new Types are added.
Updated Inserts, Side FF, and Standalone FE Products Combo Box Values for "Door Type", "Drawer Type", and "FE Type" to be latest that will build automatically from Door Wizard as new Types are added.
Corrected issues with 2D Elv View Instructions for Flip Up Door Swing and Regular Door Swings. Included adding missing layers across shipping draw templates.
Corrected Door Wizard Variable control types that were set to 0 to 10
Set the standard File Wood Drawer Slide Selection in the Wizard to Accuride 4034
Removed orphaned Global variable Back_Rabbet_Depth since no longer in use
Corrected Salice Inset and Half Overlay 3D Drawings for 110 and 120 Deg. Also added 6mm plate 3D and 2D Drawings and numerous other drawing fixes, plus global fix regarding plate for inset.
Resolved issue where Pulls not appearing on Solid Wood Drawer Fronts with Flat or Raised Panel, due to Y Origin and supporting prompts not calculating correctly.
Corrected Door Wizard Variables D!Inside_Edge_Profile_Drawer and D!Raised_Panel_Profile_Drawer formulas to reference Drawer Choices not Tall
Updated G!Construction_Hole_Z_Value_Drawer to default to half the thickness of the "Drawer Box Wood Front Back" in Materials.
Changed G!List_Drawer_Slides to read LookUpTableSystemDrawerSlide for list of drawer slides
Updated Adjustable and Fixed Shelves subassembly to accommodate a Rear Line bore feature.
Deleted the product "Straight Countertop w Butt Splash" as it was actually the same product as "Straight Countertop w Splash".
G!Start Hanger Notch Base, Tall, Upper changed to =Nailer_Width-0.25
Updated Access Panel subassembly so parts come in on same AutoCAD layer as other cabinet parts
Updated Base Carcass to support applied back machining at sides
Removed Associated_Parts_Left/Right/Divisions from all 4 opening splitter subassemblies
Vertical Opening Splitter|Horizontal Opening Splitter removed from G!List_Interior_Components
Fixed Closet Basket insert subassemblies. Two blocks were appearing for each basket.
Corrected Molding Estimating Product. Additional Price/Cost prompts were added in error.
Fixed Toggle Bolt hardware drill depth. Both holes should be =0.629*G!Unit_Factor
G!Base_Thick_Back_Inset (and others) now set to 0.3125". This should default the back insets to be the same between thick backs and regular backs.
ADA sink cabinets and other cabinets with no bottom had their Bottom_Thickness prompt hard locked to zero. Set this to be a formula like other cabinets as this was causing issues with the Sexbolt holes not aligning with adjacent cabinets.
For all drawer subassemblies, in the Associated_Parts_Left and Associated_Parts_Right prompts these parts are named "Suspended Left Side FE" and "Suspended Right Side FE". Upon removing the word SIDE from both prompts, the machining will be restored for the slides.
Changed Full Top Material Name prompt for the cabinet full top in drawer banks.
Fixed issue in Single Division SA. Material names were locked to Base category instead of Base, Tall, Upper.
Fixed issue in Single Fixed Shelf SA. Edgeband material name was not checking L!
Numerous changes and fixes to Blum Legrabox and Tandembox drawers.
Added new AutoCAD dwt template MV Drawing Template.dwt to provide new automation and features.
Updated Wall room component - various changes to accommodate 2D dims
Updated 3D draw tokens for cabinet sides at Finished Ends. Will now change color at finished ends.
Updated all 2D Section draw dim parameters (par 9).
Corrected a number of Dovetail Drawer errors that effected Metric
Door Single Slab, Solid Wood, MDF, and MDF w Machining, "Pull_Center" prompt formula says G!Pull_Horizontal_Base at end and should be G!Pull_Center_Base. Door Left and Rights subs are correct.
G!Lock_Left_Door_Upper was not within the Door Left and Right subassembly Locked Door prompt logic.
Corrected lock placement issue in single door subassemblies when reveals left and right were a different value.
Build 46.0
Microvellum Build 15.4.1517 or higher is required.
New Products:
Decorative Panel product with curved bottom rail and angled stiles for hood and other decorative panels.
Mitered End Panel, Mitered Shelf Products to enable thick panel product construction
Island Starter Product to enable creation of islands with cabinets on all 4 sides, corner extensions, corbel and column details and base moldings.
Mitered Panel Starter
Counter Surround product for drawing islands with mitered returns to floor.
1 Drawer Microwave Base
Coat Closet
Door Frame
Stairs
Cabinet Fronts Only
Face Panels
Single Door or Drawer Front
Light Panel Product with cutouts for puck lights and wiring chases.
Table Product with turned or tapered legs and apron parts.
Extruded Molding Products for creation of valances, base moldings and crown molding with part creation for optimization of valance and return parts including joint allocations.
Diagonal Corner Sink Base
Top Hinge Upper
New Subassemblies:
Wine Rack Interior Components for Lattice System, Divisions, X styles
Back Insert
Mirror Back
Glass Shelf
Drawer Blum Tandembox Antaro
Mitered Box
Cutout Subassembly to create cutouts with radiuses on any of 5 interior cabinet surfaces
Spice Pullout Vibo Wire
Blind Corner pullout hardware inserts for Wari-corner, Magic-Corner, Magic-Corner II Comfort, Flymoon
Subassembly category "Appliances" with 3 new appliance inserts: Microwave, Oven, & Sink.
5 new subassemblies used for new machinable MDF Doors, Drawer Fronts, and FE Panels
Door Left MDF w Machining
Door Right MDF w Machining
Door Single MDF w Machining
Drawer Front MDF w Machining
False Front MDF w Machining
New Features/Improvements:
Updated all Side Face Frame subassemblies. Numerous improvements made to accommodate adjacent cabinets (similar to Tall applied FE subs).
Activate Applied Back Machining whenever back is applied over part edge, regardless of whether the entire back is applied.
Made improvements to drawer inserts that prevent a “half overlay” setting when in a face frame opening.
Rear Modifications features will now work for Face Frame cabinets
Updates to 2D Drawing Tokens
Add 2D Plan View tokens to Diagonal cabinets.
Updates to 2D Plan View tokens to draw correctly for outline of transition cabinets.
Add Drawing token for correct representation of Microwave cabinets
Update Section dims to properly align and reference Global Variables for placement.
Correct placement of Filler Elev Dim
Update Base Counter Top Subs to account for Extend Counter Left/Right
Add 2D Plan View tokens to corner cabinets to correctly show cabinet sides and angle and draw with fillers.
Updates to draw curved cabinets
Corrections to Upper Cabinet Elevations
Correct plan tokens for FE Panel products
Update tokens for divisions to draw correctly with Open Finish
Add 2D plan Drawing tokens for Doors and Fillers
Add 2D Dimensions to plan views.
Add product code to plan views.
Updates to shelf elevation tokens to turn on and off and control text styles.
New Leg Leveler options, controls
Added support for stop dado construction at cabinet thick backs
Overhaul of Corner Fillers & Regular Filler Products
Change G!Pulls Autosize Center to G!Pulls Center to allow all pulls to be centered on doors, not just autosize
Allow Custom Autosize Pull setup (any pull can now be an “autosize” pull)
Added None option to list drawer system to allow quick removal of drawer box
Eliminate separate sink counter top subassembly so any cabinet can have a sink added - allows for quick creation of drawer sink cabinet
Add grain direction options for doors, backs, sides at product level
Add options for grain matching across multiple products.
Add grain direction symbols for elevation drawings.
Added Blum Tandembox Antaro for drawers, files, rollouts, with options for sink drain cutouts and rollout front hardware
"Magic Wire" hardware for fixed and adjustable shelves
Adjust placement of adjustable shelves to draw in actual locations on shelf pins.
Added mitered panel option to horizontal and vertical splitters.
Added virtual splitter option to allow division of cabinets into sections without actual parts between them
Updated "Wall" Room Component. Windows and doors with option for trim in dimensions, multiple doors/windows per wall. Added "Obstructions" tab with Bulkhead & Column options. Added parameters for a Vaulted Ceiling option.
Updated numerous cabinet prompts related to door systems. Control types, prompt values, prompt hidden formulas, etc for all doors, drawer fronts, & applied FE panels all updated to support a new machinable MDF Door method.
Updated Tandembox Antaro and Legrabox subassemblies. Now includes cutout options for plumbing or other obstacles. Added reference to Grain Direction prompts. Adjusted location of Antaro parts to place correctly for rollouts. Added option to rotate rollout spacers if name ends in “Horizontal”.
Back Construction, Machining, and Drafting variables removed from Project Wizard. They have been returned to the Global Variables.
Added File Drawer Hardware to Drawer Standard Wood Box File
Added Drawer slide hardware Blum Movento 760 40kg & Blum Movento 766 60kg
Refactored the Aventos lift up cabinets. Now can utilize any door library (not just slab)
Updates to Room Components:
Updates to 2D Drawing tokens for walls to correctly show elevations and dimensions of doors, windows, obstructions.
Addition of Bulkhead and Column Options for walls.
Allowance for more than 1 door in wall
Allowance for double doors
Update to allow calculation of door with to trim or frame dimensions for accurate placement
Allowance for custom windows and doors with proper representation
Allowance for vaulted ceilings parallel and perpendicular to walls.
Updates to Appliances
Updates to bring consistency and ease of additional items
Removed Room Component categories Dishwasher, Ranges, and Refrigerators. Added new category "Appliances - Kitchen"
Creation of 2D Elevation views for all appliances
Update prompts to allow variable width between cabinets to allow for ease of placement of appliances and surrounding cabinets.
Creation of generic appliances to allow on the fly creation of custom appliances for Refrigerators, Ranges, Dishwashers
Creation of Microwave and Oven subassembly inserts for use in product starters or other products.
Includes virtual routing tokens for panel cutouts, options for oven panels and trim kits as well as additional support shelves to be included with appliance inserts.
Creation of generic sink product with up to 4 variable width/depth/height bowls including cutouts and 2D drawings for Drop-in or undermount.
Added jpg help images for appliances (Product Prompt Images folder)
Bug Fixes & Miscellaneous Changes:
Corrections to corner cabinets
Allow thick back construction as per standard cabinets, linked to Globals.
Dimensions for Rear Corner clip CORNERNOTCH and CHAMFER in products and shelves along with updates to follow back construction correctly.
Updates to correct back with Edit Material selection.
Correct location of Fixed Shelf
Corrections to Dado nips for tops and bottoms
Corrections to material assignments and thickness calculations.
Corrections to screw in finished tops/bottoms
Corrections to screw drilling with finished ends
Updates to Cornernotch and Chamfer tokens should respect Stop_Dado_Nip_Rout_Face to keep machining on 1 face
Updates to Leg leveler locations for Pie Cut/Diagonal Base Assemblies
Updates to Finish Back references.
Corrections to thick back dado calculations
Verified all products' Width/Height/Depth values. Corrected ones with hard values.
Corrected dwg blocks for Accuride 3732 drawer slides.
Corrected dwg blocks for Accuride 7432 drawer slides. Right hand slides needed to be mirrored.
1 Double Door Tall FF (Face Frame) had some missing prompts
Added "Hinge Name FF" hidden prompt to Drawer Bank FF & Starter FF products.
Global variable value for "Applied Back Machining" changed to "Pilot Hole Back".
Updated Associative Rotation formula for Strike Plate hardware in all doors
Corrected several issues related to Rollouts and the custom calculator feature used to position them in Z Origin.
"Rollouts" Interior Component Subassembly will now calculate spacing correctly and has a calculator
"Rollout Height From Bottom" global variable changed to 1/2" to help clear spacer collision with bottom hinge
Updates made to Left/Right Finished Panel products
Updates made to Side Face Frames and Applied FE Subassemblies. Added improvements and functionality. Fixed some issues related to mitered edges.
Updated "Use_Single_Solid_Wood_Front_SA" prompt in solid wood drawer fronts. Will now respond to the "Top_Drawer_Front_Default_To_Slab" option in the Door Wizard.
Updated Extruded Part Collection product.
Fixed issues with 2 & 3 Suspended drawer products when drawer fronts are Inset.
Updated global variable "Pull Double Pull Location" to support Face Frame drawer bank products.
Updated Adjustable and Fixed Shelves subassembly. Corrected issue with 3 sided notch rear modification.
Numerous changes to Gang Lock feature.
Updated dwg block.
Removed [Ganglock Lockbar Rout] token from Base Right Side part in Base Carcass. Now uses Virtual Rout tokens in drawer stack inserts for gang lock machining.
Added additional hardware items related to Ganglock feature into all drawer front subassemblies
"Fixed Shelf Thickness" Prompts now reference Edit Material options
Added missing "Material Name" prompts to starter products.
Single Fixed Shelf Subassembly will now have a correct material name (not just Base material)
Corrected dado machining issues in Single Fixed Shelf Subassembly
Closure Panel Product will now space away from wall the depth value
Leg levelers will now place correctly on Transition cabinets
Base Assembly Subassembly now manages multiple Leg Leveler Selections by using a new LookUpTable
Added additional leg leveler options: Hafele 3 Screw On, Hafele 4 Screw On, Berenson Screw On White
Updated Base Assembly Diagonal & Pie Cut to match changes in Base Assembly sub.
Added new global variables, product prompts, and subassembly carcass prompts to support new 2D plan view features
Updated G!LookUpTableProductPricing table to include an “Abbreviated Name” column, used in new 2D Plan View Tokens
2D Plan View outlines will now be correct for Transition, End Diagonal, Outside Corner, Inside Corner cabinets
"G!Cabinet Lock Dado Amount For Thick Backs" was not defined in Metric global
Updated G!List_Interior_Components to support new subassemblies
Added Drawer Blum Tandembox Antaro to G!LookUpTableSystemDrawer & G!LookUpTableSystemRollout
Space Screws Equally
Center Pull On Stiles and Rails
Adj Shelf Setback Glass
Max Span Glass
Shelf Clip Gap Glass
Use Tandembox Size C
Split Drawers From Doors
Split Double Width Cabinets
Allow Grain Matching Across Multiple Products
Show Perfect Grain ID on Elevation
Side Grain Direction
Back Grain Direction
Use Dado on Drawer Divisions
Use Dado on Divisions
Always Add Panel at Double Doors
Always Add Panel at Double Drawers
Stop Dado Length Thick Back
Stop Dado Thick Back Condition
List Interior Components 1 Door Blind Corner
Use Magic Wire for Fixed Shelves
Use Magic Wire for Adjustable Shelves
Shelf Bore Dia Glass
Magic Wire Bore Dia
Magic Wire Bore Depth
Color Label Text Style
Finished End Text Style
Shelf Annotation Text Style Elevation
Shelf Annotation Text Style Section
Perfect Grain Text Style
Adjustable Shelf Annotation
Fixed Shelf Annotation
Draw Grain Direction
Door Grain Symbol Location
Drawer Grain Symbol Location
Grain Symbol Layer
Pull Auto Size Minimum Clearance
Extend FF Bot Rail To Floor
Extend Side FF Stiles To Floor
Extend Side FF Bot Rail To Floor
Floor Scribe
Increase Applied Ends Bot Rail At Floor
Align Applied Ends Bot Rail to Face
Increase Rear Stile at FE Scribe
Increase Side FF Rear Stile at FE Scribe
Min Pocket Default Tool
Alternate Pocket Tool
Min Pocket Size
ADA Sink Thick Back
Wall Offset Distance Base
Wall Offset Distance Tall
Wall Offset Distance Upper
Drawer Bottom Grain Direction
Drawer Back Grain Direction
Door Reveal Tool
Removed orphaned global variables:
FE_Panel_Overlay
FE_Panel_Overlay_Open
Vert_Shelf_Hole_Space1
Vert_Shelf_Hole_Space2
Applied_FE_Panel_Left
Applied_FE_Panel_Right
Door_Buyout
Drawer_Front_Buyout
List_Door_Panel_Types
List_Drawer_Front_Types
List_Drawer_Front_Panel_Types
List_Finished_End_Types
List_Finished_End_Panel_Types
Global "Finished End Grain Direction" renamed to "Side Grain Direction"
Added new Project Wizard Variables.
Drawer Front Grain Direction
Door Grain Direction
Drill For Pulls
Draw Counter Tops
Counter Top Splash Height
Product 2D Plan View
Include Plan Description
Plan Dimension Depth at Finished Ends
Include Plan Width Dimension
Added new "Autosize Pulls" variables to Project Wizard
In all Door Subassemblies, Rename Prompt "Pull Auto Size Center" to "Pull Center"
Added "Space Screws Equally" prompt to all carcass subassemblies
Updated all screw CONST tokens in carcass subassemblies to support new "Space Screws Equally" feature
Updated "Adjustable and Fixed Shelves" & "Adjustable and Fixed Shelves Trans" subassembly with new "Magic Wire" feature. Option is supported for both adjustable and fixed shelves. Also added new shelf Z origin logic so adj shelves align with linebore holes.
Added "Side Grain Direction" & "Back Grain Direction" prompts to all carcass subassemblies. Changed part grain formula for Sides. Added part grain formula for backs.
Added prompt "ItemNumber" to the remainder of products still missing it (frameless cabinets)
Added prompts to all cabinet products to support new grain direction feature:
Grain Matching Identifier
Added new Interior Component subassemblies:
Wari Corner Pullout
Magic Corner Pullout
Magic Corner II Comfort Pullout
Lemans Corner Pullout
Garbage Pullout US Cargo
Garbage Pullout Revashelf 5349
Garbage Pullout Euro Cargo
Flymoon Pullout
Updated subassemblies Single Division, Divisions with Shelves, and Square Spiral Insert to look at G!Use_Dado_on_Divisions
Updated subassembly "Drawer Division" to look at G!Use_Dado_on_Drawer_Divisions
Updated Door Drawer products to respond to new G!Always Add Panel at Double Doors, G!Always Add Panel at Double Drawers
Updated "Divisions with Shelves" subassembly. Had issue with shelf thickness value coming from L! when it should be using actual shelf thickness being calculated inside S!
Removed Invisible Fastener Lockdowel option for wood drawers (still needs to be developed)
Refactored construction tokens & cutparts inside corner cabinets
Added additional Interior Component Selections to Blind Corner cabinets
Wari Corner Pullout
Flymoon Pullout
Changes made to cross-section tokens for cabinets. Better alignment of dimensions for base & upper cabinets.
Updated Base Countertop subassembly. Corrected some issues and now has a Sink option.
Removed "Base Sink Counter Top" & "Base Transition Counter Top" subassemblies from library (and products). Now using "Base Counter Top".
Base Counter Top Subassembly - FE 2D Elevation lines will now take into account Extend Counter Left/Right
2D elevation of Counter Top will now display splash line at finished end conditions
Removed Add Sink Prompt and sink width warnings if Draw Countertops is off
Corrected Blind Corner Cabinet Issues - 2 Door Blind had interference when using overlay panel and blind hinge panel, all blind corners did not respect blind corner width+blind reveal when using inset panel and blind hinge panel - dimension is reduced by door overlay.
Updated Base/Tall/Upper Corner Filler products. Added features, resolved numerous issues
Updated Base/Tall/Upper Scribe Filler products. Added features, resolved numerous issues
The global variable "G!Screw Drilling At Finished Ends" will now cause screw drilling to appear at finished ends when set to "Drill Through".
Open Base/Tall/Upper Corner products will now mirror properly (Toolbox Mirror Product command)
Updated Aventos HF cabinet warning message formula
Corrected Transition Carcass fillers (placed incorrectly in 3d and 2d plan)
Microwave Upper will now draw Bottom in 2D elevation
Upper cabinet Filler 2D Elev Dimensions now showing above cabinet
Upper corner cabinets now use upper material pointers instead of base
Upper corner cabinets will now calculate thick back thickness correctly when "Edit Material" feature is used.
2d Plan View of cabinets now on individual BASE, TALL, UPPER layers instead of all 2D_DASHED
Added "Hide Unexposed Parts" prompt to all drawer subassemblies
Modified global variable "Extend FF Stiles To Floor". Changed from Checkbox to Combo Box with None|Always|Fin End|Applied FE|Side FF|Applied FE and Side FF|All FE Types
Made changes to Base and Tall Face Frames Subassemblies to support the new options "G!Extend_FF_Stiles_To_Floor" & "G!Extend_FF_Bot_Rail_To_Floor"
Added two new prompts to all Base and Tall cabinets, Extend_Panel_to_Floor_Left & Extend_Panel_to_Floor_Right
Updated Subassembly rows for Applied FE entries to support new Extend Panel to Floor options (new Height & Z Origin formulas)
Updated Subassembly rows for Applied Back Panel entries to support new Extend Panel to Floor options (new Height & Z Origin formulas)
Corrected Face Frame separate Bead Frame Z origin at corner cabinets
Updates to all 6 Left/Right Finished End Products. Added support for Floor Scribe plus several other changes
Updated Applied FE subassemblies, Finished Back Panels, Side Face Frames to support new options such as extending stiles/rails to the floor variable.
Added "Sink Options" tab to all sink cabinet prompt pages.
Added "Custom" as a sink choice option. This activates a new "Sink" subassembly and new prompts with a variety of options to enable representation of a generic sink (3D & 2D).
Created "Appliance Cabinets" category. Moved cabinet products with built-in appliances to this location.
Base Countertop Subassembly will now display 2D Plan & Elevation drawings correctly when Applied FE Panel Left/Right is selected.
Added two missing Blind corner Overlay hinge dwg files
Changed G!Base_Molding_Type to default to "Furniture Toe Base"
Removed hard locked tool numbers from Legrabox subassemblies
G!Use_Shelf_Clips_With_Fixing_Plug global variables will now create machining on shelves.
Fixed Dado nip issue in sink sub front
Added global variable "ADA Sink Thick Back" and pointed ADA sink cabinets to it.
Changed Blind Panels so edge banding will turn off at W1/W2 when Inset
Corrected imperial values located in the metric global G!LookupTableInvisibleFasteners columns 6,7 & 21
Removed all formula references to "Finished_Back=1" as this no longer possible.
Updated material thicknesses of most metric sheet materials. Now are exact scaled equivalent to imperial materials (not rounded). This will solve issues with the metric EPB template and other SMA drawings that are scaled from imperial.
Updated Extruded Product Builder Metric.dwt. Resolved issues that came when scaling from imperial.
Corrected 2 Drawer 2 Door Insert subassembly. Global could not find S!Top_Left_Full_Extension which caused errors in some drawers.
Added WallOffset prompt to most all products that would typically be associated to a wall.
Added Vertical Opening Splitter|Horizontal Opening Splitter to G!List Interior Components
Updated reports requiring changes due to the new FLATSHOT draw token (Face Frame Report, Product Detail, Metafile Product Picture Report).
Added formula to Global variables "List Pull Types Inch" & "List Pull Types Metric". Will now pull list of pulls from LookUpTablePullType
Updated 3 Filler Products: "Base/Tall/Upper Filler w Return". Added option for applied end panels on sides as well as face. Added option for finished back.
Corrected Upper Carcass Inset Blind panel not adjusting z position for bottom valance height
Added Side Face Frame subassemblies to all FF Starter products
Added "Drawer Blum Legrabox" to G!LookUpTableSystemRollout
Updated Face Frame Mid Rail/Mid Stile subassemblies. Removed FF draw tokens (now using Flatshot tokens).
Updated Misc Part product. Added the option to select material from the prompts. Part will now orient correctly with 2D plan view.
Updated global variable "List Interior Components 1 Door Blind Corner"
Added missing imperial global "ADA Sink Thick Back"
Updated Subassembly Prompt "Pull_Center"
Corrected issue where Custom Sink can extend outside cabinet
Corrected issues with Door Drawer inserts and Vertical Opening splitter. Inset door condition caused issues with shelves and stretchers.
Corrected issue in Single Door Inserts when they were in the bottom opening of a vertical starter
Color_Label_Text_Style prompt in all products/subassemblies now reference the global instead of the wizard.
Plan Description draw tokens now point to global G!Plan_Description_Text_Style
Added 3D_File Bar Clip 500482290.dwg & 3D_File Bar Corner 500482190.dwg to \Graphics\Hardware
Added File Bar Rail Material
Added "Draw Microwave" option to 2 Door Microwave Upper
Removed DRAW2DADJ & DRAW2DFIXED from shelf inserts as they do not work with Annotative. Updated the Adjustable shelf subassemblies to use DRAW2DBOX, added elevation tokens with the ADJ/FIXED text.
Updated \Graphics\CommonBlocks\ItemSymbol3DAnno.DWG (imperial and metric)
Updated Extruded Base – changed Route to Pline tokens, added decorative cutout option
Stretcher Frame Product Code changed to "TB" so it shows correctly in Adjust wall length command
Single Door Subassembly Updates (4x) - Add Top Hinge SA prompt, Update Hinge QTY value and control type, Update Hinge__Angle Control, Update Use Bumpers value, Update Pull Center and Pull Horizontal values, Update Pull Type, Update Base/Tall/Upper Door Override to force always Upper, Update Door Part Names, Add Single part to first line of Solid Wood Subassemblies.
Deleted Subassemblies - Door Upper Aventos Slab, Door Uplifting Slab
Added Subassembly - Door Uplifting Hardware. Updated Flip Up Door.
Added new Top Hinge Upper product
Removed GLobal LookUpTables - LookUpTableAventosHF, LookUpTableAventosHFHeight, LookUpTableAventosHK, LookUpTableAventosHKS, LookUpTableAventosHL, LookUpTableAventosHS, LookUpTableTopHingeHardware
Default Upper Cabinet depth changed to 13" (330mm)
Updated Global Variables - PB Weight, MDF Weight, Solid Lumber Weight, Glass Weight
Single Door Subassembly Updates (4x) to remove Pie Cut Door Subassemblies - Update Diagonal Door value, added new prompts: Pie Cut Hinge Door, Pie Cut Pull Door, Hinge Name PieCut, Bifold Hinge Plate Inset From Door
Left/Right Door Subassembly Updates (8x) - Add Left Hinge Plate Y, Right Hinge Plate X prompts (to allow for double door diagonal)
Changed Subassembly Name formulas in Pie Cut Cabinets to be like all the rest (no pie cut reference)
Deleted Subassemblies - Door Single Pie Cut MDF Hinge, Door Single Pie Cut MDF Pull, Door Single Pie Cut MDF w Machining Hinge, Door Single Pie Cut MDF w Machining Pull, Door Single Pie Cut Slab Hinge, Door Single Pie Cut Slab Pull, Door Single Pie Cut Solid Wood Hinge, Door Single Pie Cut Solid Wood Pull
Updated Sink subassembly to accommodate Diagonal Corner Sink Base product
Added Floor Scribe amount to toe kick notches in applied FE Slabs
Build 45.0
Added new machining category called “Invisible Fasteners."
Lockdowel H-Clip
Lockdowel Channel Lock
Lockdowel 9mm Channel Lock
FastenLink
Data added to Project Wizard, Global Variables, and all carcass subassemblies
Independent control for cabinet Tops/Bottoms/Fixed Shelves, Thick Backs, Stretchers, Nailers, and Toe Kicks
Initially supports the following:
Please note that some additional library modifications may be required to fully comply to Lockdowel’s recommended construction details.
Fixed issue with Lazy Susan block not appearing in face frame corner cabinets
Added ItemSymbol3DAnno.DWG and ItemSymbolAnno.DWG to CommonBlocks folder. Used when Annotative Scaling option is selected.
Could not see “Hide Unexposed Cabinet Parts” in the Metric Global. Had wrong category link ID.
Rollout Spacer Left/Right in 2 Door cabinet products now point to G!Rollout_Spacer_At_Hinges
Based on MVUAG feedback, global Construction Holes Z Value changed to 0.375" (9.5mm). Construction Hole Z Value Drawer changed to 0.25" (6mm).
Corrected issue with Dust Panel stretcher in Door/Drawer & Drawer Bank products. Issue occurred with inset doors and drawers selected with full Dust Panel option.
Added Global variables “Shelf Standard Rout From Top Upper and Tall Cabinet” & “Shelf Standard Rout From Fixed Shelf”
Restored "Fixed Lengths" feature for Shelf Standards option. Eliminated Phantom Shelf Part for Standard Machining. Added Machine tokens to each shelf that work similarly to the linebore ones that turn on and off using the new prompts added. Also added the missing Corner Notch Standard Routing Machined tokens that were missing. Added Activity tokens to each shelf.
Removed 3 unused global variables: “Nailer_Use_Base”, “Nailer_Use_Tall”, ”Nailer_Use_Upper”
Divisions with Shelves subassembly, the equations for the edge tape Width_1, Length_1, and Width_2 all erroneously reference the following non existing prompt: "Adjustable_Shelf_Edgeband_Material_Name_Opening_1"
Corrected issues with Side Face Frame w FE Panels
Added missing prompt "Hinge Name FF" to all FF cabinets with doors. Without this, anytime you change to a FF hinge that requires an overlay other than 1/2", the overlay will be incorrect.
Corrected 1 Double Drawer and 2 Double Drawer inserts. Had incorrect division thickness when "G!Use Double Drawer Division" option was selected.
Corrected minor screw hole token issues on Thick Backs.
Correction made to Thick Back Dado tokens. Parameter 8 should reference Back_Dado_Depth instead of Cabinet_Dado_Depth.
Added global variable G!Drawer_Division_Setback and pointed the drawer division SA to it (instead of G!Division_Setback).
Updated Access Panel subassembly. Corrected and improved a number of items.
Corrected issue in subassembly inserts with drawer fronts. If Generic 5 Piece type was selected, the wrong subassembly was turning on.
Updated all SA inserts w Doors & Drawers. Changes you make such as Door Hinge Stile Width in the main cabinet will now trickle down to all subassembly inserts that may be present
"Back Dado Depth" variable in carcasses broken out with Back Dado Depth Left, Back Dado Depth Right, Back Dado Depth Top, Back Dado Depth Bottom. This was done to accommodate Lockdowel construction which has a different back dado depth at tops & bottoms vs the sides. Also needed to break out "Back Capture Amount" into the four different directions.
Corrected issue in Face Frame cabinets with Rollouts. Should be using Opening_X instead of Opening_X_FF
Base Carcass now has a "Full Top Cutout" option. Added to accommodate Lockdowel construction requirements.
Added new experimental product "Base Starter Horizontal FF Multi Carcass". Product still “under construction”.
Removed "G!Rear Stretcher Nip" global variable (unused).
Made several improvements/fixes to edge banding of parts in Tall and Upper cabinets.
Modified drawer division inside face frame door drawer products to behave similar to suspended products
3D Shelves are no longer on CabinetInterior and OpenCabinetInterior layers. Now on SHELF and OPEN_SHELF.
Improved how drawer top gaps are calculated. Many changes made to prompts & globals.
Improvements made to Drawer Blum Metabox/Tandembox subassemblies
Added missing Tandembox Size N Rear Bracket Graphics
Removed 11 of the 12 default AutoCAD drawing templates. Renamed "Design 01.dwt" to "Default.dwt"
Modified Nailer Y Origin formula.
Modified Back Inset formula in all cabinet products to better support the Full Applied back option.
Replaced all references to "<UserFiles>" in DRAWBLOCK tokens. Should be "<Graphics>"
Added a number of draw tokens to demonstrate the new "Dynamic Product Image" feature. All frameless and face frame cabinets have new draw tokens under the Metafile Instructions area. Added a new checkbox prompt called "Dynamic Product Image Exploded View".
2 Door Microwave Upper Fixed Shelf will now capture shorter back when "Open Back Oven" is checked
Added global variable "Saw Lead". Pointed all formulas to use this when SAW token is used at cabinet backs.
Added a number of new prompts to all carcass subassemblies to give more control over back dado lead ins/outs and separation between DADO with router vs SAW
Made numerous changes to better accommodate Locks, Strike Plates, Magnetic Catches in different conditions (such as face frame)
Deleted "Division_Width" prompt from products as it is now calculated in the subassemblies
"Division Setback" prompt will now control the "Division Setback" inside the "Shelves with Divisions" interior component. "Top_Bottom_Inset" variable will now automatically be added to the division setback amount.
Changed Associative Rotation of drawer front locks to "0"
Made updates to side face frames and finished end panels.
Added prompt to all upper products "Use Tall Applied FE Panels".
Added "Hinge Inset Frame Inside Overlay Threshold" global variable
Changed the Door subassembly prompt "Hinge Plate Location Standard Door" to better support different Face Frame conditions
Added "Slide Inset Frame Inside Overlay Threshold" global variable
Changed drawer subassembly Width and X Origin formulas to accommodate "Slide Inset Frame Inside Overlay Threshold" global variable
Made multiple edits to all subassembly inserts (and splitters) with drawers to accommodate the new "Slide Inset Frame Inside Overlay Threshold" global variable
Changed "Back Toe Groove" global variable to
Build 44.1
Added library categories to better-organized Frame and Frameless cabinet categories
Corrected Finish Back prompt in corner cabinets.
Toe Kick Notch Relief unselected as a global default
Fixed issue with Wardrobe Tall Cabinets. Shelf and Pole had wrong Z origin because of changes made to shelf and pole insert.
Corrected minor issue in Rollout Subassembly
Added "|Shelf and Pole Insert" to the global "List Interior Components".
Purged ItemSymbol3D out of Metric dwt Template files. This was causing item numbers to be incorrect size for metric installs.
Corrected issue in Die Wall w Studs Only
Build 44.0
Removed all graphics files from the graphics database. All DWG and JPG files are now "on disk" like v67. Entire folder structure containing the blocks re-constructed.
Merged the MDF Door data from the Australian library. Numerous changes made to the product’s prompt screen, new subassemblies added, new router bit graphics added, and new tools added to sample tool file. When selecting the MV MDF Door System door library, a new Door Type option is available called “Routed w Machining”. This option will produce code for running doors on your machine. Options and variables can be accessed from the project wizard and the door subassembly prompts. Please note that this initial release is for testing only and not necessarily ready for full production yet.
Added Blum Legrabox drawer system
Added Open End Diagonal products (and their subassemblies). Base, Tall, & Upper. Frame & Frameless.
Corrected issue with screw construction holes at finished ends.
Updated hardware machine token spreadsheets. Needed to add "-Tall Adj Shelf, -Tall Fixed Shelf " to the name filter list in hinges to avoid unwanted machining on shelves.
Inside opening splitters (and other SA inserts) removed "Rollouts" option from opening interior component selection combo box prompts. This was creating a double nested subassembly, which Toolbox does not support.
Added more Door/Drawer SA Inserts for face frame conditions.
G!Disable_Door_Lines
global variable was not being referenced.
Added G!Disable_Drawer_Lines global variable. Added draw token to all drawer fronts to show a diagonal DashDot line on 2D elevation.
Added 2 Drawer 1 Rail insert, 4 Drawer 1 Rail, 4 Drawer 3 Rail, 2 Door Sink w False Front 1 Rail
Added new global variable "Reverse View FF Draw Tokens".
Corrected Doors in 1 Double Door Tall. They were not overlaying correctly at the fixed shelf.
Corrected issue inside Doors that was preventing the correct hinges to appear at Face Frame inset door conditions. Updated "Hinge System Calc" prompt.
Made small change to door subassemblies so hinge plates will still appear at face frame conditions with small inside FF overlays (i.e. 0.03125")
Updated Shelf and Pole Insert. Corrected reported errors. Added a prompt to control the rod height so the rod isn't sitting on the bottom of the pick corners.
"Lock Selection Drawer Stack Fronts" in project Wizard had incorrect combo box formula. Should be =G!List_Locks_Drawer_Stack_Fronts
Updated Adj and Fixed shelf quantity prompts in all Tall products to improve reporting. Removed the Hide On Reports formula.
Rollout Dovetail Wood Box: Moved the prompt "Drawer Width" to be above the first blank row (solves a reporting issue).
Selecting "None" as a Pull choice will now give a quantity of zero for the pull hardware. This should clean up unwanted entries from appearing on hardware reports.
Corrected issues in the Extruded Part Collection product
Corrected issue with Microwave Upper Thick Back Z Origin
Updated scrap reports and labels
Build 43.4
Fixed issue in 2 Door Blind Left Corner Upper. X origin for Right Door was incorrect.
Fixed issue in some of the Stanisci Range Hoods.
Added a new Angled Hood from the Stanisci parametric that allows some customization.
Added new extruded die wall "v2.5" product. Fixed some issues with the horizontal toe placement, added the ability to control the skin materials independently.
Added new Extruded Parts Collection product to create a collection of horizontal and vertical parts.
Removed all references to "L!" inside the Carcass Base Non-Subassembly product.
Left/Right rear corner notches will now work properly with all back construction options.
Restored drawer bank cabinet “Gang Lock” feature from v039.
Fixed issue in 2 Door 2 Drawer Base cabinets with inset drawer fronts.
Removed some duplicate manufacturing reports. Added new reports for Fluid Designer
Added additional functionality for face frame drawings. Added option for reverse view inside Base Haunched face frame. This feature is still under development and is currently limited to base cabinets.
Build 43.3
Corrected issue with inset doors when the door is nested.
Added 6 King Slide drawer slides
Adjustable and Fixed shelf edge feature did not work properly when Profile edge was selected.
Added a new interior component, Square Spiral Insert
Updated Single Door subassembly inserts. Was not responding correctly to Left/Right door swing in Vertical Starters.
Corrections made to the Blum Aventos HK-S uplifting hardware
Corrected issue with face frame mid stiles at starter cabinets. Separate bead option was not added to length of part.
Made changes/fixes to all shelf subassemblies. Improved Shelf Opening Calculator by adding the 4th parameter. Also reversed the order of the Opening prompts to make it more dynamic when changing number of shelves and re-running the calculator.
Numerous areas updated to properly accommodate the Separate Bead face frame option.
Corrected issue with Door/Drawer Blind Corner products when using a "Double" drawer divider
Corrected issue in Divisions with Shelves subassembly. Prompts "Turn Off Screw Holes Top" & "Turn Off Screw Holes Bottom" were not working when "Combine Dowel and Screw Pattern" was selected.
Updated all Base Assemblies so Leg Levelers will work with FF cabinets.
Updated ADA Sink Angled Frame to accommodate a different thickness material for finished end vs unfinished.
Rollout Interior Component will now default with an appropriate number of rollouts based on the height of the opening space.
Fixed the sides of the Tall Cabinet that should be looking to the global named “Machine Origin Tall Sides” instead of “Machine Origin Base Sides”.
Added "Machine_Origin_For_Sides" prompt to all carcass subassemblies and pointed formulas to look at this instead of Global.
Updated all Left/Right Side Dado, Dowel, Screw, & Camlock machine tokens in Carcass subs. They now respond correctly to changes made to Machine_Origin_For_Sides when Inset Side Top/Bottom is used.
Added Open Base End Diagonal product. More versions coming soon (Tall, Upper, Face Frame, etc.)
Build 43.2
Added cross-section data to "Adjustable and Fixed Shelves" & "Divisions with Shelves" inserts. Now shows "ADJ" or "FIXED" at each shelf.
Updated all three Vertical Starter FF products. They now have a Double Fixed Shelf option (behind each stile).
Door Single Solid Wood
subassembly had a blank row on the Hardware tab, disconnecting pulls and other hardware.
Updated Vertical Opening Splitter FF. All mid-rails had incorrect width and X origin when using the Haunched option.
Updated Horizontal Opening Splitter FF. All mid stiles had incorrect height and Z origin when using the Haunched option.
Updated face frame Mid Rail & Stile single part inserts. Added additional prompts to help with the virtual rout haunch feature.
Add "Hinge with Flap Stay" to the G!List_Uplifting_Mechanisms list. Imperial Global had it missing.
Added “Horizontal Opening Splitter” to Bay Options prompts inside all Starter products.
"Show 2D Elv Face Frame Parts" will now be visible in global UI.
feature will now be unselected by default at finished end conditions.
Fixed issues with the Door Bumper feature. Had issues with the Continuous Pull option. Simplified formulas. Hooked up local prompts so they can control door bumpers.
Added part name filters to the Door Bumper hardware item machining. This will ensure only the doors get machined.
Fixed numerous issues with pie cut corner door subassemblies. Deleted the following subassemblies:
Door Base Single Pie Cut Slab Hinge
Door Upper Single Pie Cut Slab Pull
Door Base Single Pie Cut Solid Wood Hinge
Door Base Single Pie Cut Solid Wood Pull
Door Upper Single Pie Cut Solid Wood Hinge
Door Upper Single Pie Cut Solid Wood Pull
Door Base Single Pie Cut MDF Hinge
Door Base Single Pie Cut MDF Pull
Door Upper Single Pie Cut MDF Hinge
Door Upper Single Pie Cut MDF Pull
Added the following subassemblies:
Build 43.1
Added Flip Up Door option to Starter Products. Also available as single subassembly insert.
Updated global variable “List Uplifting Mechanisms” to include “Hinge with Flap Stay”
Hooked up the global variable Force_Inset_Toe_Kick_at_FE.
Tool for cabinet right side toe kick notch wrong. Should be using Default_Routing_Tool_CCW. Update token on Right Side and the Virtual Rout token.
Machine Token for Left/Right dowel holes at toe kick parts was not responding correctly to Notched_Toe_Kick_Position variable.
Added a 1 Double Drawer and 2 Double Drawer insert
Added 1 Dbl 2 Single Drawer Base and 1 Dbl 2 Single Drawer Base FF products
Added 3 Drawer Base w 1 Rail FF product
Edited all drawer insert subassemblies so they know if they are in a face frame opening vs a frameless opening.
Renamed Specification Groups (removed “Frameless”)
Updated manufacturing and Micromanager reports/labels
Build 43.0
Added new Face Frame cabinet products & categories. If Face Frame products are not needed by your company, simply delete them and their categories with the Database Explorer tool. Any face frame subassemblies can be removed as well.
Because of the merging of two libraries (Face Frame & Frameless), starting with version 043.0 this library is now called the Component Cabinet Library.
Updated Grass Unigrass drawer subassemblies
Fixed issue in Divisions with Shelves Interior Component. Shelves will now equally space in all conditions by default.
Added prompt warning messages to Pie Cut Corner Cabinets to prevent bad user inputs.
Corrected issue in blind corner products involving the Inset Blind Panel and Blind Hinge Panel.
Fixed issue inside Suspended Cabinets when using the Double Drawer Division option.
Transferred the “Back Panel” product into the Miscellaneous category (from Face Frame Library)
Filler products now have a “Split Panels” feature, plus several other improvements.
Fixed dado issue inside Single Drawer Stretcher subassembly
Upper Starter products had incorrect references to "Base" for their Applied FE and Back panel subassemblies
Drawer bank & some door/drawer products had Top/Bottom Thickness Prompts missing logic.
Updated Horizontal Opening Splitter. Hinges missing at some 2 Door options.
Door/Drw Front Overlay & Inset prompt options will now always be visible at the same time.
Added Base/Tall/Upper Starter Vertical Products. Operates similar to a regular starter product, but goes vertically instead of left to right.
Renamed Starter products to: Base Starter Horizontal, Tall Starter Horizontal, Upper Starter Horizontal.
Added 2 Door Base w Range Top & 2 Drawer Base w Range Top products (Frame & Frameless).
Added Pocket Doors category to Hardware Library.
Added Pocket Door hardware and their machine tokens to HWRX file.
Added Pocket Door subassembly inserts.
Added Pocket Door options to Bay Options in Starter Products.
Added Pocket Door hardware 3D CAD graphics.
Added Pocket Door hardware JPG prompt help graphics.
Added missing reference to Continuous Pull-in Drawer Front Height formula. Should say =Height-IF(Pull_Type="Continuous",G!Pull_Continuous_Width,0)
Global Variable "Finger Pull Horizontal Reveal" was set wrong. Should say =ROUND(0.75*Unit_Factor,Accuracy)
Numerous other small corrections & improvements made since previous version. Contact Technical Support for complete list if desired.
Build 42.2
Added 3 new Open Base/Tall/Upper Corner products
Fixed issue with shelf standards at upper cabinets. The global variable G!Shelf_Standard_Rout_From_Bottom_Upper_Cabinet should be ½” by default.
Fixed issue with uppers that had a bottom valance option. Door Z origin was effected.
Fixed issue with the sexbolt connector feature at certain conditions.
Removed the following unused global variables:
Horz Hole Spacing Finger Pull Rail
Center Holes Sub Front
Sink Vertical Rail Screw Spacing
Sink Vertical Rear Rail Screw Spacing
Horz Hole Spacing Sink Vertical Rear Rails
Reverse Rear Stretcher Machining
Added Face Frame categories and variables to the global variables. Will be used in the future when face frame cabinets are added.
Build 42.1
Corrected reported issues with Horizontal and Vertical Splitter inserts. Door overlays and shelf quantities were not always correct.
In some subassemblies, the variable prompt Turn Off Screw Holes Right Side was incorrectly looking to the Left Side.
Corrected issue with top doors in 4 Door Oven Cabinet
Added the ability to turn on/off dowels and/or screws in the Vertical Splitter insert.
Range Hood
library category added
Added additional products to the Wall Fillers category. Fillers that have angled faces, flute options, & Rosette appliques.
Corrected issue with Drawer Stretchers at inset conditions
The global variable Construction Hole Offset will now properly offset dowel & screw holes at fixed shelves & divisions. Works for all construction patterns in MV version 2015 R3 or newer.
1 Door 1 Drawer insert will now respond to Door Swing options in Starter Products.
Bottom post laminate parts added to upper products
ADA sink cabinets now have their thick backs set to “Captured Sides and Top”
Fixed issue with part thicknesses when Post Laminate End option is selected in Drawer Bank products.
Removed duplicate category folder in the Global Variables
Corrected issue with the Global Variable Machine Origin Base Sides. Was incorrectly affecting tall or upper conditions in corner & transition products.
Corrected issue with nailer dowel machining when Remove Back option is selected
Corrected issue with the Single Fixed Shelf subassembly insert. It was incorrectly displaying ADJ instead of FIXED in 2d elevation. This affected double door tall products.
Build 42.0
2D Color Labels will now turn on/off correctly from the Project Wizard
Added Hettich MultiTech drawer system
Shelf Row Spacing
option now supported inside each shelf subassembly. Previously this option was only available in the global variables. MV version 2015 R3 or newer required.
Added new opening quantity parameter to custom calculators that benefit from this new feature. MV version 2015 R3 or newer required.
Removed orphaned LinkIDLocations and RoomNames from Products table inside Factory Database.
Toe Kick Relief Notch
feature will now machine Right Sides on face 5 instead of face 6
Toe Kick Pocket Notch
feature will now work in conjunction with Toe Kick Relief Notch
Added new global variables to control the direction of grain at the part level. Selecting Length or Width will force parts on grained material to orientate the desired direction. This will only affect parts on material that has grain. Currently, there are these three variables:
Because of the new ability to control part grain direction, the need to rotate parts by switching the part length & width is no longer necessary. All parts and hardware affected by the original global variable Drawer Front Grain Direction have been simplified by utilizing this new technique. Perfect grain patterns supported in MV version 2015 R3 or newer.
Added a Rollouts Interior Component subassembly.
Fixed issue with part thicknesses when Post Laminate End option is selected.
Global variables Rear Stretcher Qty and Front Stretcher Qty renamed to Rear Stretcher and Front Stretcher. Products with stretchers now linked to look at these variables.
Added a new non-subassembly starter product
Build 41.0
Added a new Rear Modifications features to most all cabinet products. Unlike previous library versions, we no longer require the user to add additional subassemblies to modify the backsides of cabinets (previously called Corner Clips). Instead, the options can be found on the main prompts page of the cabinets that contain this functionality. By selecting a checkbox, a new prompt tab appears containing all the variables. These include:
Corner Notch Left
Corner Chamfer Left
Corner Notch Right
Corner Chamfer Right
Three Sided Notch
Top-Notch
Bottom Notch
Corrected issue in Drawer Division & Single Division subassemblies that affected Screw Machining.
Corrected issue in Drawer Division length & origin when using dado construction
Hanger Notch prompts will now control the carcass subassemblies correctly.
Added missing drawer stretchers to 7 Drawer Base
Added a new feature to Blind Corner Cabinets called Notch Inset Blind Panel. This will inset the blind panel into the face of the carcass and notch the affected parts as needed. It also changed some of the positionings of the parts in door drawer conditions.
Base_Nailer_Inset
Base_Nailer_Inset_Open
Tall_Nailer_Inset
Tall_Nailer_Inset_Open
Upper_Nailer_Inset
Upper_Nailer_Inset_Open
Inside Depth Base
Inside Depth Drawer Stack
Inside Depth Sink
Inside Depth Tall
Inside Depth Upper
Hanger_Notch_Upper_Bottom_Height
Tongue_Width
Added Split Back feature to Thick Backs in main carcass subassemblies.
Corrected issues in Tall/Upper Starter products with Top/Bottom Valance options
Corrected issue with the new Machine Origin Base/Tall Sides option. It was incorrectly affecting upper products using the same shelf insert subassembly.
The Single Drawer Stretcher and Single Fixed Shelf subassemblies now have the same default Base Point setting. This was inconsistent before and caused issues with the Vertical Opening Splitter when using stretchers. Drawer Stretcher’s Z Origin inside all Drawer Bank and Door Drawer products were modified.
Fixed issue in Thick Backs when using alternating dowel/screw machining.
Data has been added to all products to demonstrate/support a new Mirror Product Toolbox feature.
ProductCode
hidden prompt added to several products that were missing it. This will be used more extensively in the future for various Toolbox features. For example, the Edit Wall Length will be using this to determine if a product is a Base, Tall, Upper, Countertop, Toe Base, etc.
Build 40.3
Corrected issues in the Shelves with Shelf Std product. Added a Finished/Unfinished option
Corrected issue in Starter Products when Bay Qty is 1.
Updated all reports, including manufacturing, received material labels, time clock, pallet reports/labels, purchase order, etc.
Wardrobe products added to Tall Cabinets category
Build 40.2
Sample tool file updated to the current version
Fixed issues with Finished Back options when “unfinished” was not selected
Fixed issue with Door Drawer products that affected the calculation of interior parts
Corrected issues with Sink Sub Front machining
Added Global Variable Cabinet Lock Dado Amount For Thick Backs
Fixed issue with Rollout spacing in tall cabinets
Redundant 2D Draw Tokens removed from all cabinet products. 2D Plan, Elevation, Section tokens now controlled from the cabinet carcass.
Redundant Product Activity Tokens removed from the cabinet products. Now calculated in the cabinet carcasses.
Added Elias Woodwork Door Library
Curved Front products restored
Fixed issue when Shelf Row Quantity was set to zero with Divisions with Shelves Interior Component.
Expanded the Hardware Subassembly category to contain additional sub-categories.
Build 40.1
Numerous reported small items cleaned up
Corrected several issues with Dado construction
Machining options for Angled Transition products completed
Corrected 2D elevation view of Open Upper Cabinets
Removed Door Valance Top/Bottom prompt from open cabinet products
Fixed issue with Sink False Front parts at inset conditions
Cam tokens added to Thick Backs
All Dowel, Screw, Cam machining updated for Nailers, Toe Kicks, Stretchers. They now operate similarly to other cabinet parts.
Project wizard improved to help with selecting machining options
Machining issues resolved when cabinet Tops/Bottoms capture Sides.
PLINE toe kick option moved from a machine token to a virtual route in the subassembly
Added missing sexbolt holes
Metric version now available
Build 40.0
A major rebuild of all cabinet products. All cut parts have been removed and consolidated into carcass subassemblies. All cabinet construction & machining options have been re-written. All adj shelves, fixed shelves, divisions, & dividers have been consolidated into “Interior Component” subassemblies. These changes will provide a much easier workflow when needing to make library modifications or improvements.
Because of the new construction & machining structure, many global variables have been removed (too many to list). There is a net difference of 363 fewer global variables.
New Prompt Tab added to all cabinets called “Product Materials”. This can be used to make local changes to part materials without causing material thickness issues inside the formulas.
Fixed formula issue for Toe Kick Front lengths in Transition cabinets
Fixed issue with Scribe Route feature on Finished End parts.
Upper Corner products will now have hanger notches for non-finished ends if the global option G!Hanger_Notch_Uppers is selected.
Changed LTSCALE setting in AutoCAD dwt templates.
Added MicroManager Activity Tokens to Corner Cabinet parts.
The global variable G!Pull_Move_Up_For_Valance will now affect upper cabinets.
Apron product now has correct Y origin for it’s parts
All Price and Cost prompts now use the same Prompt Index number (15). This was done by editing all the Tab Lists of every product to accommodate the different numbers of tabs.
Additional tools have been added to help automate things surrounding 2D drafting for users.
A new Drafting tab has been added to all cabinet products.
A new Drafting tab has been added to the Project Wizard.
Fixed issues with the Access Panel insert.
Restored the Custom Pull feature. This allows a method of adding a temporary pull quickly to a project by using a hardware material pointer.
The Product Corner Clips subassembly category has been removed. In a future library update, these rear cabinet clips will become a part of the cabinet instead of separate subassembly inserts.
Product Starters have been completely rewritten. They no longer use the built-in internal opening calculator, but rather use the custom calculator feature located inside the prompts worksheet. These starters no longer require special “Bay Insert” subassemblies to populate their bay openings. We now have combo box options inside various prompt tabs for each opening. This provides a much quicker workflow in designing custom products.
Opening Splitters
subassembly inserts have been rewritten to include options for interior components for each opening.
Routing a hole for door locks will now appear on face 5 by default.
A new shelf standard machine token has been deployed. This will require Microvellum Toolbox version 2015 r2 or newer.
Double Door Tall cabinets now have door swing options in the main prompts.
Build 39.2
Corner Clip Inserts will now notch thick shelves (wide span)
Removed illegal characters used in global variables for rollout spacers
Fixed HeightAboveFloor feature in Left/Right Finished Panel for Upper products
Fixed Machine Token errors in extruded die wall products
Improved the Single Parts Product. Added new material selection interface to prompts (new control types). Added missing lookup table data.
Corrected several issues with drawer divider parts at dado conditions.
Corrected drawer divider parts at open suspended products.
All Transition products will now respond to G!Miter_Angled_Cabinet_Sides variable.
Corrected issue with Blind Panel Scribe variable in Blind Corner products.
Corrected Bottom Y Origin formula in Upper Transition products.
Removed additional TenonCAM machine tokens and references inside Dado formulas.
Removed global variables File_Drawer_Min_Height & File_Drawer_Front_Height
Added additional sample Employees, Departments, & Activities for MicroManager’s scheduling module.
Build 39.1
Build 39.0
Coat hook hardware now has associative hardware machining
Y Origin issues with Wine Rack insert resolved
Corrected missing front skin on Extruded Die Wall product
Corrected G!LookUpTableMoldingProfiles that had an incorrectly defined range
Corrected the Toe Kick Notch on Right Sides for Sink Products when using the Toe_Kick_Notch_Relief option.
Diagnostic G Code Test Product added
Build 38.0
To improve performance, removed the prompt “Total Product Edgebanding” from all products/subassemblies as it was not being used. Also re-wrote many of the Costing formulas to bypass custom functions when they are not needed. This resulted in significant improvements to the processing performance.
TenonCAM Dado feature has been removed to simplify the Dado machine tokens.
Removed PARTTHICKNESSM custom function from many areas. This was done to address performance issues.
Added the following Global Variables
Drawer_Box_File_Drawer_Bottom_Wide_Span_Thickness
Drawer_Box_File_Drawer_Bottom_Thickness
Drawer_Box_Wood_Bottom_Wide_Span_Thickness
Drawer_Box_Wood_Bottom_Thickness
Build 37.1
Issues resolved inside the Curved Front products.
Build 37.0
Common Blocks DWG files copied from the MicrovellumGraphics database and put on disk located in the folder “CommonBlocks”.
All 2D cross-section, elevation, and plan drawing instructions for Cabinet Products re-written and now include additional annotations that demonstrate ideas for using 2D Draw Tokens.
Added the following Global Variables:
G!Elev_Dim_Offset_Baseline
G!Elev_Dim_Offset_Vertical
G!Sect_Dim_Offset_Baseline
G!Sect_Dim_Offset_Vertical
G!Dimension_Gaps
G!Toe_Kick_Notch_Tool_CW
G!Toe_Kick_Notch_Tool_CCW
Duplicate Machine Tokens removed from all parts. This was causing issues with Library Designer.
Added 3 more subassembly inserts inside the Door and Drawers category
2 Drawer
3 Drawer
4 Drawer
Build 36.2
Build 36.1
Numerous reported small issues addressed
Corrected Adj Shelf Linebore Qty in Metric global variable
Countertop Self Edge pointers now loose laminate instead of plywood
Corrected drawer slide hole location when using plant on bottom feature
Issues with Max drawer depth feature fixed
Corrected edgebanding in Sub Front parts in Sink Cabinets
Countertop splash height now looking at global variable instead of local hard value
Double Door Tall products will now update pull choices in door subassemblies
Corrections made to Extruded Die Wall products
Build 36.0
All Activity Stations and Tokens have been rewritten. Version 7.5.158.xxx or newer required.
Cost-Based settings no longer look to the Global Variables. They only look to the project wizard.
Added new Custom Estimating Products for Price Based and Cost Based systems
Added Molding Estimating product
Updated many Reports
Fixed issue with Base Front Stretchers and Cam Lock construction
Fixed issue with Finished End Scribe feature
Build 35.1
The global Grass File Slide will now properly control the Drawer Grass Unigrass File subassembly
Added Rollout Dovetail Wood Box option
Fixed issue with Hanger Notch Upper Bottom feature
Updated ten placed part labels with the ability to read multiple sheets
Pre-drill machining for applied backs now correctly points to the global variable “Dim_To_Const_Hole_Back”. Also, the distance between holes will now always be an equal distance.
Sample tool file has been updated
Fixed issues with the Auto Size Pull option not displaying in 2D elevation
Build 35.0
Corrected numerous spelling and grammar problems through the entire library.
Updated reports to the latest versions
Added local control to door bottom gaps on Upper Microwave and Corner products
Build 34.1
Fixed issue with Reveal Override prompts inside 1 & 2 Double Door Tall products
Fixed issues with Blum and Grass metal drawer systems
Fixed issue with Extruded Die Wall product missing parts
Added price based prompts to custom estimating product
Build 34.0
To lessen confusion, the build version increased to 34.0 to match other library build numbers. Moving forward, each multi-library database release will have the same version number for each library contained inside.
The global variables Hinge Tall Center Option and Hinge Tall Center Offset have been restored. Hinge Qty formula inside doors modified to accommodate the features.
Nest Dado option for drawers no longer have face 6 machining for set screw holes.
Removed several orphaned materials from database and cutpart files
Fixed some issues with Sink Opening Bay Insert Subassemblies
Single/Full Extension Radio Buttons will now only appear for Drawer Types that use them.
Added “Is Buyout” prompt checkbox to indicate product or subassembly is a Buyout item. This will cause all parts, edgebanding, and hardware to be considered buyout, so the parts will draw, but be omitted from the work order and not manufactured.
Build 30.0
New global Hide Unexposed Cabinet Parts added to control how cabinets are drawn in 3D. Checking this option will cause the program to only draw parts that are exposed. This can greatly increase performance while navigating around your 3D drawings. A local prompt is also available to control this on selective products.
Related Articles
Component Cabinet Library Release Notes | Build 50.7
The following release notes apply to Component Cabinet Library, Build 050.7 Additions Added Products: Upper Starter Horizontal FF Multi Carcass Pullout Base 1 Drawer with Pullout Pullout Base FF Upper Starter Split Height Upper Starter Split Height ...
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
