Accessing the Edit Design Data InterfaceThere are several ways to access the Edit Design Data interface: When drawing products (Draw > Draw Products), you can right-click in the product list, expand the “More” list at the bottom of the menu, and ...
The Edit Design Data interface is a spreadsheet editor, similar to Microsoft Excel. The interface includes tools located at the top of the window. Below the tool icons is a drop-down list of defined names that can be used to locate the cell’s ...
We are working to improve the usability of Microvellum software. Some of our Users have asked for the ability to edit multiple prompt values from the drawing. This boosts the speed at which the program may be used since the prompts do not require ...
The Prompts tab is where all the prompts that are visible within the Product Prompts are located. The Prompts tab also contains hidden prompts. Hidden prompts begin after the first blank row in the Defined Name column. Prompt is another term for a ...
The purpose of this article is to provide a reference for the new Subassembly Save Options interface. This reference applies to Toolbox builds 15.6.2201 and greater. See Save Subassembly to Template Check Prompts (Overview) in the Microvellum Help ...
