This article highlights special prompts that Microvellum’s software specifically looks for to trigger certain events and features. DATABASE PROMPTS It is critical the three product/subassembly prompts below remain intact and unaltered in their ...
We are working to improve the usability of Microvellum software. Some of our Users have asked for the ability to edit multiple prompt values from the drawing. This boosts the speed at which the program may be used since the prompts do not require ...
The purpose of this article is to provide insight of the Global Variables when interacting inside the Toolbox Interface. How to Access the Global Variables With Toolbox open, click "Toolbox Setup > Project Specification Groups." Select the desired ...
This article provides a list and detailing of the options available for products in the Microvellum Foundation Library. Construction Methods See below for a collection of screenshots showing the various construction methods available. These can be ...
