This article summarizes working with Specification Group Components.
For a summary of the Library Specifications Groups Interface, see:
For a summary of the Project Wizard, Global Variables, Material Files, and Door Wizard Interfaces, see:
For working with Specification Group Collections, see:
To copy a component, you will need
to select the component, and click the Copy icon (or right-click and select
Copy (Make New) Component). Give the component a new name. It is recommended
that you create a standard naming convention for your components for better
organization.
To rename a component, you will
need to select the component and click the Rename icon (or right-click and
select Rename Selected Component).
To delete a component, you will
need to select an unused component (orange text), and click the Delete icon (or
right-click and select Delete Unused Component).
To assign a component to a
collection, you must select the component in the right section as well as in the
left section under the particular collection you want it assigned. To complete
the assignment, click the arrow between the left and right sections.
