Solid Modeling Tools - Extruded Products The Solid Modeling Tools interface allows you to work with the product builders to create custom products. Using these tools, you can work within the drawing to create 3D solids of parts and then save them ...
Modify Products Tab Part Properties See the Part Properties section within the Knowledge Network. Edit Multiple Product Prompts See How to Modify Multiple Products using Edit Multiple Product Prompts. Replace Products See Using the Replace Products ...
The following article highlights the Extruded Molding Products for Manufacturing in the Foundation Library. The video below demonstartes adding the Extruded Products to Upper Cabinets. Extruded Molding Products are intended for use in manufacturing ...
Solid Modeling Tools - Custom Products Before using the Custom Product Builder, it is important to determine which type of custom product you will be building. There are five options to select from: Custom Product Starter – This option allows you to ...
