Create and Configure a CutRite Processing Station in Microvellum
Before performing the actions itemized in this tutorial, you must have completed two tasks as outlined in the article “Cut Rite PTX Parts File Import from Microvellum (Overview).” Click  here to see that article.
  • Purchase & configure the Cut Rite® software from Stiles Machinery to consume the PTX file.
  • Create a project and work order in Microvellum.
This tutorial utilizes the Microvellum work order and demonstrates how to configure a Cut Rite® processing station within Microvellum. Processing with that station results in a file of the type “Parts & Boards – ASCII/Unicode CSV,” with a PTX file extension. That file is then optimized inside Cut Rite for optimized results.
Tutorial: Create and Configure a CutRite Processing Station in Microvellum
  1. Depending on the version of Microvellum, use one of the methods below to access the screen to set up a new processing station.
    1. Click Toolbox Setup > Processing Station Setup. If your version does not contain that command path, click Toolbox Setup > Options > Processing Stations. One of these two commands opens the processing station management screen.
    2. Click the button for Edit Existing Work Order and select a work order to open it and display the processing station management screen.
    3. Fig. 01 – Processing Station Management Screen
  2. Click the Add button in the Processing Stations section of the screen.
  3. Fig. 02 – Add Processing Station Button
  4. Add a station Name in the appropriate box. (The box for Activity Station may remain blank.)
  5. Drop down the list box and select a station Type of “Cut Rite Parts File.”
  6. Click the Settings tab and enter Premill Type and Auto Assign Rules as necessary for your company. See information on those subjects elsewhere in the Microvellum help system.
  7. Fig. 03 – Processing Station Settings
  8. Click the Associates tab and add any secondary processing stations as required to pass edgebore or single part barcodes passed through to the Cut Rite parts file.
    You must first set up all your necessary processing stations in the Processing Station Management screen, then follow the steps below.
    1. Click the Add button (plus mark icon) to add a blank row.
    2. Click the cell in that new blank row in the Index column and enter or select a number that represents the priority of data to appear on the labels. In other words, if you have multiple machines that produce the same type of G-Code, such as multiple point-to-point machines or multiple edgeboring machines, the lower this number, the higher that Associate will be in priority for displaying its data on the labels.
    3. Click the cell in that new blank row in the Type column and enter or select one of the processing station types from the list.
    4. Click the cell in that new blank row in the Name column and enter or select one of the processing stations from the list. These are stations that have already been set up from the Processing Stations Management screen.
    5. To delete an existing Associate, select the line to delete, and click the Delete button (trash can icon). Click Yes to confirm the deletion.
      Fig. 04 – Processing Station Associates Showing One Point-to-Point and Two Edgeboring Associates
  9. Click the Files & Pictures tab to set various properties necessary to create the Cut Rite PTX import files.
    1. In the “File Location” section, click the Browse button to select a folder where the Cut Rite PTX files will be created.
    2. In the “Part Picture File Location” section click the Browse button to select a folder where any part picture files for use with an auto-labeling machine are to be created.
      1. Select the Picture Type, Pixel Size, and Zoom Factor as needed by the auto-labeling system.
      2. If the Picture Type “WMF” is selected, you may also select the option for “Use Legacy WMF Format” if required by your auto-labeling system.
      3. Fig. 05 – Processing Station Files & Picture Properties
You have now completed the creation and configuration of your Cut Rite station. You are now ready to process work order data with that station and the others you have created to support your complete manufacturing process.
Lastly, but outside the scope of this article since Cut Rite is a third-party software, you need to configure it to import or consume the PTX part and board (sheet) data produced by Microvellum. In general, when importing parts, there are at least two things to set up. The first is the Path for Import Data, which is where you specify where the files to import are located. You may also need to set up additional parameters at File > Import parts > File > Parameters.” In addition to those two, there may also be other Cut Rite properties that need to be set. See the NOTE below.
Microvellum does not provide support for setting up your Cut Rite system. See the Cut Rite help system for specific tasks and details, or contact your Cut Rite representative.
When your Cut Rite system has been set up, and the PTX file imported, optimize your data using Cut Rite.
A sample PTX file created using this tutorial is attached as an example of its format.
    • Cut Rite PTX Parts File Import from Microvellum (Overview)
      Introduction Microvellum contains complete nesting optimizer and complete sawing optimizer solutions. It also supports the third-party optimizer Cut Rite manufactured by Stiles Machinery/Homag Group. There are two methods of communication between ...
    • Create and Configure a BlueCell Processing Station in Microvellum
      Before performing the actions itemized, you must have completed three tasks as outlined in the article “BlueCell XML Parts File Import from Microvellum (Overview).” Click here to view that article. Purchase & configure the BlueCell® software from ...
    • Processing Station Associates for Reports
      For information about setting up part transformation functions required for builds 15.6.2404 through 21.1.0604, see Configuring Part Transformation Functions (Legacy Support). This article contains a detailed reference for setting up and using the ...
    • Parts File Processing Station Associates (Overview)
      Overview of Processing Station Parts File Associates Microvellum contains complete nesting optimizer and complete sawing optimizer solutions. It also supports third-party optimizers such as Ardis, BlueCell, and CutRite. Microvellum creates a “parts ...
    • Nesting Processing Station Controls and Settings
      To access the settings for a processing station, select the processing station and click the Edit icon. The Settings tab for the processing stations is the same across the different types of processing stations. Name – Allows you to set the name for ...
    • Microvellum Foundation Library Release Notes | Build 26.0527
    • Microvellum Release Notes | Build 26.1.0529.641
