Related Articles
Understanding What a Subassembly Is
Understanding What a Subassembly Is Subassemblies are smaller products inside of another product. Subassemblies are also shared within a project. For example, the subassembly, Carcass Base, is shared across all the base cabinets in a project. The ...
Adding Subassembly Inserts and Using Pick Corners
Adding Subassembly Inserts and Using Pick Corners The lists of subassemblies within the product starters may not contain a particular subassembly. In that case, a subassembly will need to be added to the product. The Subassemblies interface will ...
Understanding the Subassembly Save Levels
Subassembly Save Levels When working in the Subassembly Prompts, there are different save options located at the bottom of the interface. Because subassemblies are shared across a project, multiple save levels have been incorporated to allow you to ...
Subassembly Cabinet Modifiers
The video featured in this article covers the following subassembly modifiers: Base Arch Cutout Base Deco Cutout Base Three Sided Cutout Glass Insert Left and Right Chamfer Corner Flutes To access the subassembly modifiers featured in this video, ...
Understanding the Subassemblies Tab
The subassemblies tab will display the subassemblies that the product is currently referencing. A subassembly works the same way a product does. It contains its own set of parts, hardware, and prompts. A subassembly can also contain more ...
