Deployment of Microvellum to Azure
Choosing the right sized virtual machines (VM) in Azure depends on several factors, including your workload requirements, budget, and expected performance. You will need to work closely with an IT professional experienced in Azure to deploy Virtual Machines capable of running Microvellum and other applications in the cloud.
Here are things to consider with your IT when selecting the right VM sizes to run Microvellum and your applications:
Steps to Choosing the Right Sized Virtual Machines in Azure
- Identify Your Current Workload:
- Current Compute Capability: Determine the number of CPUs and the amount of RAM you are currently using for all Microvellum and other application for each of your servers and workstations.
- Current Storage: Assess how much and what type of storage (Standard HDD, Standard SSD, Premium SSD) you are currently using for servers, workstations, and file storage.
- Current Network: Determine your current network bandwidth and latency.
- Special Situations: Determine your current GPU capabilities, high IOPS storage, or other specific features.
- Current Database: Determine the following:
- Database Size: The version of SQL (SQL Server 2019, etc.), current size of the database, and expected growth based on past metrics.
- Concurrency: Number of concurrent users and transactions.
- Performance: Current IOPS, CPU, and memory used.
- Identify Workload Requirements You Would Like to Improve
- Compute Requirements: Determine if the number of CPUs and the amount of RAM you are currently using is sufficient or if you would like to increase the number of CPU’s or amount of RAM for each of your servers and workstations.
- Storage Requirements: Determine if you need more storage or better performance and then decide how much and what type of storage (Standard HDD, Standard SSD, Premium SSD) you would like to use to improve performance of your servers, workstations, and file storage.
- Network Requirements: Determine if your current network bandwidth and latency meets your needs or determine what improvements you would like to see.
- Special Requirements: Determine if you would like to improve performance in GPU capabilities (Hardware Acceleration for AutoCAD, etc.), high IOPS storage, or other specific features.
- Database Requirements: Determine if you need to improve Database Size, Concurrency, or performance.
- Understand VM Families: Azure VMs are categorized into different families based on their intended use case:
- General Purpose (B, Dsv3, Dv3): Balanced CPU-to-memory ratio. Suitable for web servers, small to medium databases, and development/test environments.
- Compute Optimized (Fsv2, Fs): High CPU-to-memory ratio. Ideal for batch processing, web servers, and application servers.
- Memory Optimized (Es, Ev3, M): High memory-to-CPU ratio. Best for relational databases, large caches, and in-memory analytics.
- Storage Optimized (Ls, Lsv2): High disk throughput and IOPS. Suitable for big data, SQL, and NoSQL databases.
- GPU (NC, NV, ND): Specialized VMs with GPU capabilities. Used for machine learning, AI, and graphics rendering.
- High Performance Compute (H): High throughput and low latency network. Ideal for high-performance computing workloads.
- Get a more detailed overview here: https://learn.microsoft.com/en-us/azure/virtual-machines/sizes/overview
- Use Azure VM Sizing Tools:
- Azure Pricing Calculator: Use the Azure Pricing Calculator to estimate costs and compare different VM sizes.
- Azure Advisor: After the setup of Azure, this tool provides recommendations on VM sizes based on your current usage.
- Azure Migrate: For larger scale setups this tool can help assess and right-size VMs based on on-premises workloads.
- Review Performance Benchmarks:
- Azure VM Performance Benchmarks: Review performance benchmarks and case studies for different VM sizes to understand how they perform under various workloads.
- Here are some performance benchmarks done by Microsoft: https://learn.microsoft.com/en-us/azure/virtual-machines/windows/compute-benchmark-scores
- Budget Constraints:
- Balance performance needs with budget constraints by selecting a VM size that provides the best value for money.
- Reserved Instances: Consider using reserved instances if you have predictable workloads, as they offer significant cost savings over pay-as-you-go pricing.
- Evaluate Different Sizes:
- Pilot Testing: Deploy Microvellum and your application on different VM sizes in a test environment to determine which size meets your performance and cost requirements.
Example Deployment of Microvellum Production Environment to Azure
The following Microvellum setup was successfully deployed and evaluated in Azure as of June 27th 2024. Machine sizes are only an example. Your actual machine size may vary based on availability in azure at a given time, workload, budget, and expected requirements.
- SQL 2022 Standard on Windows Server 2022 (SQL preloaded)
- VM Family Used: E-Series (Memory Optimized)
- Machine Size: E4bds v5
- Intel Xeon Platinum 8370C 2.8GHZ (32 Cores)
- 4 vcpus
- 32 GiB memory
- OS Disk Type: Premium SSD
- Microvellum Product Installed: Microvellum Server (Optional, not needed unless purchased)
- Windows 11 Pro (Microvellum Production Order Entry and Processing Only)
- VM Family Used: D-Series (General Purpose)
- Machine Size: D4s v3
- Intel® Xeon® 8171M 2.1GHz (32 Cores)
- 4 vcpus
- 16 GiB memory
- Microvellum Product Installed: Microvellum Production (GPU not needed due to no drawing).
- Windows 11 Pro (GPU based VM)
- VM Family Used: N-Series
- Machine Size: NV4as v4
- AMD EPYC 7v12 64-core processor (64 Cores)
- 4 vcpus
- 14 GiB memory
- AMD Radeon Instinct MI25 Graphics Card
- Microvellum Product Installed: Toolbox OEM and Standard
![](https://static.zohocdn.com/zoho-desk-editor/static/images/file.png)
Note: We do not recommend running Microvellum in Production from a local machine connected to Azure due to performance degradation and potential data loss.
Implementing Best Practices
Consult an IT Expert:
- Work with an IT professional experienced in Azure to implement best practices for security, infrastructure, network configurations, firewalls, VPN Setup, storage and backup, Active Directory integration, etc.
Documentation:
- Keep detailed documentation of your Azure setup for future reference and troubleshooting.
Related Articles
Microvellum Server System Requirements
These are the minimum estimated system requirements to run Microvellum Server. Individual situations may vary based on your specific needs and the amount of SQL data stored. This article lists the system requirements for Microvellum Server. For SQL ...
Overview: Microvellum Licenses
This document will provide a detailed explanation of the functions, form, and usage of the new SLS (software licensing system) implemented by Microvellum as of December of 2023. This system is the default licensing system intended to be used with OEM ...
About Microvellum (Legacy)
The following information applies to Microvellum software builds prior to 23.1.1205.642 The About Microvellum User Interface displays information and links related to your Microvellum software, company account details and other information and ...
About Microvellum Interface
The following information applies to Microvellum software builds 23.1.1205.642 and beyond. The About Microvellum User Interface displays information and links related to your Microvellum software, company account details and other information and ...
Recommended System Configuration for Microvellum Production
These system requirements include recommendations for Microvellum Production Operating System (64 bit): Windows 11 Windows 10 Windows 32-bit is not supported. Processor: Minimum: 2.5-2.9 gigahertz (GHz) or faster processor Preferred: 3.0+ gigahertz ...
Recent Articles
Choosing the right sized virtual machines (VM) in Azure depends on several factors, including your workload requirements, budget, and expected performance. You will need to work closely with an IT professional experienced in Azure to deploy Virtual ...
Toolbox Release Notes | Build 24.1.0625.641
The following release notes apply to Toolbox build 24.1.0625.641 Ramping Fix There was reportedly an issue occurring with ramping wherein ramping would not function properly when utilized on a 4-sided cutout machine token. When attempting to ramp ...
Microvellum Foundation Library Release Notes | Build 24.0624
The following release notes apply to Microvellum Foundation Library, Build 24.0624 Additions Added additional sample Generic Five Piece solid wood door styles: Raised Panel 5pc with Applied Molding Mitered Solid Raised Panel 5pc Mitered Haunched ...
Microvellum Foundation Library Release Notes: 2021-2024
This document catalogs all versions of the Microvellum Foundation Library released between the years of 2021-2024. This encompasses builds 20.1201 to 24.0624 (current). To download the Foundation Library in one of the builds listed in this document, ...
Microvellum Commands vs AutoCAD Commands
Toolbox, as an OEM based on AutoCAD, possesses the full range of AutoCAD commands for use in accessing AutoCAD functions, such as drawing shapes, opening menus, altering the dimensions of polylines, etc. However, it should be noted that when working ...
