In this video, we will review the prompts for products in the drawer bank cabinets category of the product library available in Toolbox. Understand the default options and learn how to manipulate the behavior of these products.
The purpose of this article is to provide insight of the Global Variables when interacting inside the Toolbox Interface. How to Access the Global Variables With Toolbox open, click "Toolbox Setup > Project Specification Groups." Select the desired ...
To begin modifying the components tied to a specification group collection, you must select a specification group collection first, indicated by the green checkmark. By clicking on the icons directly above the left section, you can modify the ...
The purpose of this article is to distinguish the difference between Microvellum's Global Variables versus its Project Wizard. The Project Wizard is composed of variables that typically fluctuate and are often changed from project to project. The ...
