Drawer Bank Cabinets: Reviewing the Prompts (1 of 3)
In this video, we will review the prompts for products in the drawer bank cabinets category of the product library available in Toolbox. Understand the default options and learn how to manipulate the behavior of these products.
This article highlights special prompts that Microvellum’s software specifically looks for to trigger certain events and features. DATABASE PROMPTS It is critical the three product/subassembly prompts below remain intact and unaltered in their ...
This video demonstrates how to use library data to adjust the drawer front heights when maintaining the same style and rail sizes as the door causes odd center panel sizes in the drawer front. Explanation of ‘reduced rail’ as it relates to drawer ...
