In this video, we will review the prompts for products in the drawer bank cabinets category of the product library available in Toolbox. Understand the default options and learn how to manipulate the behavior of these products.
This is the third article in the series giving an overview of how to configure the custom face frame images in the default Microvellum shipping libraries of build 046.2 and higher. The first articles in the series discussed how to use the default ...
MV has added an alternative process that may be easier. See this article for more information: https://community.microvellum.com/portal/en/kb/articles/create-materials-from-import-file#Import_File_Structure
