Modify Products Tab Part Properties See the Part Properties section within the Knowledge Network. Edit Multiple Product Prompts See How to Modify Multiple Products using Edit Multiple Product Prompts. Replace Products See Using the Replace Products ...
Solid Modeling Tools - Custom Products Before using the Custom Product Builder, it is important to determine which type of custom product you will be building. There are five options to select from: Custom Product Starter – This option allows you to ...
Solid Modeling Tools - Extruded Products The Solid Modeling Tools interface allows you to work with the product builders to create custom products. Using these tools, you can work within the drawing to create 3D solids of parts and then save them ...
This video explains and demonstrates how to use the center panel options in the library build 048. Flat center panel option – rabbet joint. (begin – 00:12) Modifying a raised panel to be b flat center panel. (begin – 03:20) Center panel lookup ...
