Microvellum Foundation Library Release Notes | Build 22.1102
The following release notes apply to Microvellum Foundation Library, Build 22.1102
Additions:
  1. Added Processing Station information and sorting to the Nest and Saw reports.
  2. Added Nover Krome Premium drawer system for the AU/NZ region.
  3. Grass Dynapro 40kg Soft-Close and Grass Dynapro 70kg Soft-Close is now available in the US region.
  4. The Wood Drawer Box now has a prompt option to turn off the front notch for undermount runners.
  5. Added Perfect Grain Containers (per bay) to Master Horizontal Designer Cabinets and Master Vertical Designer Cabinets. Prompts were added to give control of grain matching across bays from within the product.
  6. Added global variables to control the fixed shelf edge type and banding options. Previously the fixed and adj shelves looked at the same global.
  7. Added three Profile Door Handle options to the Door Wizard:
    1. No Profile Handle
    2. Add Splay Handle
    3. Add J Handle
Modifications:
  1. Updated “Misc Panel” product to have Machine/Base Point of 1.
  2. Renamed Krome and Krome Linea drawer systems to Nover Krome and Nover Krome Linea.
  3. Aluminum Handles options moved to the Hardware Wizard.
  4. Lift-up hardware now has its origin attached to the cabinet sides and the following details have been modified:
    1. All the lift systems have had their insertion point changed so that the 0 point is now the setback from the front edge to the first pin or screw mount.
    2. All blocks have been updated and machine tokens updated.
    3. In the lookup table for lift systems, in the hardware file, the last blank column is now used for the setback of the hardware from the carcass edge.
    4. Face Frame applications are now possible.
  5. Improvements made to the “Toilet” accessory product.
  6. Updated the Drill machine token in the Handles/Pulls to look at the L!Thickness_Door instead of the M!Base_Door_Thickness.
  7. Upper Rangehood Cabinet now uses the Component Door Subassembly For lift-up Doors.
  8. Pocket cut-outs within MV Profile Doors will now pocket from the IF(Region="US","center","centre").
Resolutions:
  1. Resolved issues in Frameless Blind Corner Cabinet products.
  2. Resolved issue in the Blum Legrabox drawer system. Back drilling was not accounting for the bottom notch.
  3. Resolved issue in the Component Drawers subassembly that prevented grain direction selections from passing down to the nested Finished Faces subassembly.
  4. The Corner Suspension Brackets subassembly updated to match recent changes to the regular suspension bracket subassembly.
  5. Extruded Bar Die Wall will now draw the foot rail.
  6. Resolved machining issue with Shadow Rails when the Overlay Top option was selected.
  7. Resolved missing/incorrect machining with certain Handle Rods.
  8. Fix Issue with Door Buffer placement on Rangehood Cabinets.
  9. Resolved issue in Lift-Up door cabinets where the profile handle option was on the wrong edge. Also corrected an issue with lock locations.
  10. Resolved issue when using Wood Drawers with the Inner Drawer (Rollout) option. The bottom drawer was positioned too low and would sometimes collide with the opening bottom depending on which runner slides were selected.
  11. Wood Drawers now point to the hardware wizard for default drawer spacer height selection.
  12. Titus Tekform Slimline drawer system "Front Fixing Bracket Hole Dia" is now 8mm (not 10mm) per manufacturer’s specifications.
  13. Free Standing Range now has width dimension on the 2D Elevation.
  14. The dishwasher's (and other appliances) width dimension is now in line with other base cabinet dimensions in the 2D Elevation.
  15. Corrected location of 2D Elevation grain symbol on the Sink False Front.
  16. Resolved issues with all style type reports to use MVValueFormat instead of Round in the Length and Width fields.
