Microvellum Foundation Library Release Notes | Build 23.0517
This update includes many changes & additions to the Microvellum Face Frame expansion. Not all users will have access to these special products. Contact your account manager for more information.
Additions:
  1.  Added new drawer system Rocheleau R13 EVO (available in Canada)
  1.  Added new undermount drawer slides Richelieu 818 and 828 EVOLUTION (available in Canada/US)
  1.  Added Hettich Novisys 8848i 105 hinges and Cross Oblong Plates.
  1.  Added Peka Magic Corner Comfort Blind Corner Pullout.
  1.  The Master Cabinet product now has an option to add a Bottom Drawer.
  1.  Added an option for Toe Kick Drawer to all standard base and tall cabinets. It can be turned on by selecting from the "Toe Kick Assembly" prompt dropdown menu. Selecting this will automatically change the sides to extend to the floor.
  1.  Added global variable to control the alignment of the bottom rail in applied ends to the bottom rail in the Face panels.
  1.  Align Applied Ends Bottom Rail To Face.
  1. Added automation to reduce drawer depths when cabinet rear modifications (notches) are turned on.
  1. Added “Face Frame Only” category with 10 new products.
  1. Updated the Master cabinet FF, all Blind Corner FF cabinets, 1, 2, and 3-drawer FF cabinets, and all Corner FF cabinets to work with the new pull-outs from the previous update.
  1. Added "Drawer Division FF" and included it to the "Base 2 Door 2 Drawer FF", "Base Open 2 Drawer FF" and the "Master Cabinet FF". It will turn on when the "Top Drawer" and "Double Top Drawer" prompts are ticked.
  1. Added an additional face frame inset hinge condition to better support the different types of hinge applications. There is a new column added to the hinge and plate tables in the hardware lookup tables and a new global prompt "Face Frame Inset Hinge Option B Inside Overlay Threshold" added to control when option B is used.
  1. Added “Bottom Rail Three Sided Notch With Arch” Face Frame Rail Modifier. Can be used in conjunction with the global “Face_Frame_Extend_Bottom_Rail_To_Floor"
  1.  Added two global variables to control allowances for FE scribes on applied ends and floor scribes.
  1.  Applied Ends Increase Rear Stile at FE Scribe.
  1.  Increase Applied Ends Bottom Rail At Floor.
Modifications:
  1.  Corner Cabinets with Two Doors will now default to use 180-degree hinges.
  1.  Starter Panel product has been modified to better support the miter edge options. Polyline depth on all miter edges will be the panel depth less 0.01.
  1.  Drawer comments inside the Inner Drawers Subassembly changed from Bottom Drawer, Second Drawer, etc. to Bottom Drawer Box, Second Drawer Box, etc. so the Drawer Box List report filters correctly and displays these as Drawer Boxes.
Resolutions:
  1.  Resolved additional issue with Door Buffer locations when using aluminum handles.
  1.  Resolved issue when frameless cabinet door reveals increased enough to require a half overlay hinge/plate.
  1. Resolved issue with the Microwave appliance subassembly. The origin will now be correct when used inside cabinet products.
  1. Resolved issue with Horizontal Designer Suspended Cabinet. Instead of using the component drawers, it now uses individual drawers and finished faces subassemblies for each bay. We have also reduced the number of bays to 5 to keep the product simplified and cleaner. We have also resolved an issue with the bay origins to account for the double-drawer division option.
  1. Resolved an imperial/metric conversion issue affecting the closet hang rails when drawing in 2D elevation.
  1. Resolved 3D graphic issue for Grass Elite Undermount 16 drawer runners.
  1. Resolved 2D plan view issue in the Wall product when using the Bulkhead feature.
  1. Missing Grain Direction data added to cabinet fillers
  1. Resolved issue with glass panel locations in the MV Profile Door
  1. Resolved issue with the Opening Z being incorrect for the single closet products. Also resolved an issue with the placement of the center shelf when the bay height is less than the height.
  1. Resolved issues with rear modification options with face frame cabinets
  1. Resolved issue with Vertical Opening Splitter FF. The Double Shelf option will now locate the shelves correctly in Z. Also added the virtual routes for the cabinet modifiers to the shelves.
  1. Applied Ends with 5 Piece Panel or MV Profile Door will now miter to the face frame when this global option is selected. Resolved issues with the side face frame as well when using miter and side clip modifications.
