Microvellum Foundation Library Release Notes | Build 23.0609
This update includes many changes, additions & resolutions to the Microvellum Face Frame, Closet, & Office Furniture expansions. Not all users will have access to these special products. Contact your account manager for more information.
Additions
  1. Added additional Hettich hinges and plates.
  1. Sensys 8631i 95 hinges and Cross Direct Plates
  1. Added new Harn Ritma Cube drawer system for the AU/NZ region. Note: Not all drawer heights have graphics at this time.
  2. Added two Lockdowel Drawer Slides:
  1. Lockdowel LDSCU-3D Undermount
  2. Lockdowel LDSMSC45
  1. Added new (beta) Lockdowel Channel Lock wood drawer box subassembly. This is an initial release for testing only at this time.
  2. Added the Timberline CompX Double Door Latch
  3. The Box End & Box End FF products greatly enhanced with new dynamic features and abilities.
  1. Added new products:
  1. Base Applied Panel Surround FF
  2. Base Island Box End
  3. Office 4 Drawer Mobile pedestals
  4. Office 2 File Mobile pedestals
  5. Office 2 Drawer & 1 File Mobile pedestals
  1. Added a new hardware “Twin Wheel Castor_67mm”. When used in a mobile pedestal product, the value after the underscore will be used as the castor height, used to calculate the space distance required.
  2. Added the "Strip Lighting" subassembly insert to all Closet products with a prompt check option to add strip lighting for each bay. We have also added it to the Foundation Master Cabinet and the Master Open Cabinet.
  3. Added a Miter/Butt Option for Face Frame Pie Cut Corner frame parts.
Modifications
  1. Cabinets with drawers will now reduce their drawer depths accordingly when using the rear modification options. Note: Not supported with designer cabinet products.
  1. Fillers & Applied End cabinet parts will now have edge-banding applied to bottom or top edges when the global variables "G!Upper_Bottom_Finished, G!Base_Bottom_Finished", etc. are selected on.
  1. The “FE” text 2D plan view draw token has been moved out of the countertop subassembly and into the 2D Instructions subassembly. We have also moved the Filler “F” 2d Plan view text away from the product description to avoid collisions. Lastly, we have moved the finished end “F” 2d Plan view text away from the cabinet to avoid collisions with other cabinets.
  1. Component Doors subassemblies now have handle prompts to link the handle settings from the parent product down to the nested subassembly doors. Changes such as horizontal handles will now pass down to the nested finished faces subassemblies.
  1. Global variable “G!Applied_Ends_To_Floor” will now affect the Base/Tall Applied Panel Products.
  1. Added to all Office Desk products the OpenID prompt and set the Product Type to "Base Open". This will now link all the CAD layers to the rendering.
  1. "LookupTablePosts" has been added to the Factory workbook for greater control when using these within products (such as the Box End).
Resolutions
  1. Resolved issue with Master Vertical Designer Cabinet, Tall Double Door cabinet, and similar - Issue with Upper Pull location at cross sections.
  1. The Wood Drawer Box now correctly using the global variable "G!Drawer_Box_Construction_Holes_Z_Value".
  1. Access Panel subassembly insert will now create a cutout when used in a cabinet with the Overlay Bottom/Top option selected.
  1. Resolved several issues with rear modification options within the face frame cabinets.
  1. Resolved issue with Base Corner Cabinet FF - Front Stretchers were giving bad default dado machining.
  1. Resolved issue with Face Frame Blind Corner cabinets when using beaded frames. Top/Bottom Rails now have the correct part length.
  1. Resolved machining issue in very wide cabinet thick back parts that were using dowel construction.
  1. Resolved issue in the one-piece face frame when using different split heights. The center stile will now be removed if the bay next to it is at the same height.
  1. Resolved issues with the Face Frame Rail Modifiers.
  1. Resolved issue with Base Molding feature within Face Frame cabinets that prevented them from drawing in 3D.
  1. Resolved issue with glass panel locations within the profile doors when pantry door was selected with more than two panels.
  1. Resolved issue with Corner Cabinets and adj shelf line bore holes into thick back when also using a notched rear corner.
  1. Hinge Location Bottom variable in Component Doors subassembly now visible.
  1. Resolved issue within the Office Open Hutch product that prevented the adj shelves to appear.
  1. Resolved issues with Office Credenza products that involved the top & bottom reveals when changing top & bottom overlay variables.
  1. Resolved Office Furniture issue with the 2d elevation tokens. Will now look correct when having an overlay top or bottom. The top and bottom will now draw on the hidden layer only when they are not overlayed or not open.
  1. Resolved issue with Office Chair product that prevented them from appearing in 3D.
  1. Removed legacy Activity Tokens from the blended locker door subassembly.
  1. Osborne Wood Product Legs and Base Moulding preview help images will now appear in the prompts UI.
  1. Resolved issue in Closet Products related to the Opening Z being incorrect for the single closet products. Also resolved an issue with the placement of the center shelf when the bay height is less than the height.
