Microvellum Foundation Library Release Notes | Build 23.0623
Additions:
- Added new Hardware Bracket Product for use in countertop support or other applications. There is a single bracket version and an array version for multiple spaced brackets.
- Added new Formed Javabox Drawer System (UK region)
- Added additional columns in global lookup tables "CustomSpacedDowels", "CustomSpacedScrews", "CustomSpacedCams" to accommodate a different hole pattern for cabinet finished ends.
- Inserted additional rows into the three global lookup tables "LookUpTableCustomSpacedDowels", "LookUpTableCustomSpacedScrews", "LookUpTableCustomSpacedCams". Some rows will now be spaced every 16mm instead of 32mm for greater accuracy. The formula for the Custom Spacing hole patterns has also been improved to use the new global variables listed below.
This change will only appear if you install a new library as the Library Update tool will not insert these additional rows or change your hole pattern formula.
- Added new global variables to provide additional controls over Custom Spacing bore patterns (below).
- Screw Min Distance To Last Hole Custom Spacing
- Screw Use Last Hole Custom Spacing
- Screw Last Hole Divisible By Custom Spacing
- Screw Finished End Target Spacing
- Cam Min Distance To Last Hole Custom Spacing
- Cam Use Last Hole Custom Spacing
- Cam Last Hole Divisible By Custom Spacing
- Cam Finished End Target Spacing
- Dowel Min Distance To Last Hole Custom Spacing
- Dowel Use Last Hole Custom Spacing
- Dowel Last Hole Divisible By Custom Spacing
- Dowel Finished End Target Spacing
Modifications:
- Removed the formula multipliers to Target Spacing columns in global "LookupTableTargetSpacingScrews", "LookupTableTargetSpacingCams", "LookupTableTargetSpacingDowels". This was done to encourage users to specify their desired behavior for hole spacing at small & large parts.
- Updated Countertop With Waterfall Ends product. Added panel quantity options and a tab with the applied back panel options.
Resolutions:
- Corrected issue within Base Door Drawer Blind Corner cabinets with full line bore holes going into the drawer area.
- Resolved Imperial/Metric issue in certain appliance products.
- Resolved Opening Lites feature inside the MV Profile Door. Corrected the calculator for the panel heights. The calculator will now display only panel 1, panel 3, panel 5, and panel 7 when selecting the "Door with Lites" option.
- Resolved issue with Wrapped Batten feature when used in cabinets with divisions.
- Resolved issue with Cam Auto Spacing that caused an incorrect number of cams in certain conditions.
