How to Configure Toolbox 2023 to Use High-Performance Graphics
The purpose of this article is to provide guidance on how to update settings on your PC to use high-performance graphics card (GPU) on systems with dual video.
PCs often have two graphics adapters: one integrated into the motherboard for basic display and another, faster one for more demanding tasks. When using Toolbox 2023, it requires a lot of graphics power, the switching between these adapters can cause display problems, poor performance, or crashes. To prevent these issues, it is best to configure the system to always use the more powerful, discrete graphics adapter for the software.
In order to get the smoothest and highest quality experience, it is recommended to be running a graphics card with 4 GB DirectX 11 compliant Graphics Processing Unit (GPU) or one from the AutoCAD Certified Graphics Hardware. An older graphics card may not be able to leverage the power of modern GPUs and multi-core CPUs and may be the cause of lag, slow loading times, or insufficient graphics.
In Windows 10, there is an option to set a high-performance graphics card for specific applications, regardless of the graphics card and driver in use. However, this feature is not available in Windows 7. To set a high-performance graphics setting for an application, you can manually configure the graphics card settings for your NVIDIA or AMD card in Windows or use the built-in option in newer versions of Windows 10.
How to Change the Graphics Settings in Windows
1. Right click the desktop and choose Display settings.
2. Scroll down and select Graphics settings.
3. Click Browse and then navigate to and select the software executable. For Toolbox 2023 it would be C:\Program Files\Microvellum\Toolbox2023\toolbox.exe. Double-click toolbox.exe to add it to the list.
4. Select the High-Performance option, then click Save and close the Settings panel.
5. Relaunch or restart the software (if it was running) and look within the program to confirm that the high-performance device is enabled.
    • Toolbox Standard 2023 Installation Best Practices
      The following article contains the recommended and necessary procedures for installing Microvellum’s Toolbox Standard AutoCAD 2023. In order to get the smoothest and highest quality experience, it is recommended to be running a graphics card with 4 ...
    • Installing Toolbox
      Below is a systematic guide for installing Microvellum Toolbox. Before installation, we recommend reviewing our Pre-Installation Instructions and System Requirements . 1. Right-click the Setup.exe file and select “Run as administrator." 2. An ...
    • Getting to Know the Toolbox Palette
      The Toolbox palette is comprised of three sections: the Toolbox, and two Tool Strips (located on each side of the Toolbox). The Toolbox can be a floating window, or it can be docked to the left or right side of the AutoCAD interface – auto-hide ...
    • Understanding the Toolbox Login Screen
      The Login Screen opens when Toolbox is launched and provides important software details and tools, as well as optional secure login functionality.  This article contains an overview of the contents of the Login Screen. Microvellum Product – Indicates ...
    • How to Install Toolbox AC (AutoCAD Companion)
      Below is a systematic guide for installing Toolbox AC. Before installation, we recommend reviewing our  Pre-Installation Instructions  and  System Requirements . Right-click on the Setup.exe file and select “Run as administrator”. Observe the initial ...
    • Toolbox Release Notes | Build 23.1.0329.641
      Toolbox Release Notes | Build 23.1.0329.641 Processing Center Resolutions: Resolved an error in the ‘View Nesting G-Code Results’ UI when trying to view DXF’s. ‘Modify Work Order’ will no longer remove certain edge band information if editing that ...
    • Microvellum Foundation Library Release Notes | Build 23.0320
      The following release notes apply to Microvellum Foundation Library, Build 23.0320. This update includes many changes & additions to the Microvellum Closet/Wardrobe Expansion. If you have not purchased this expansion, you will not have access to ...
    • Toolbox Release Notes | Build 23.1.0313.641
      Toolbox Release Notes | Build 23.1.0313.641 Label Images Resolutions: Resolved an issue with PTP stations not flipping the face 6 WMF image correctly. WMF orientation should now match the gcode. Resolved an issue with Unified Work Order databases not ...
    • Toolbox Release Notes | Build 23.1.0222.641
      The following Release Notes apply to Toolbox Build 23.1.0222.641. Machine Tokens Resolutions: We fixed a bug affecting certain libraries that used the CONST token, which led to incorrect calculations of the distance between holes. We also fixed an ...
    • Microvellum Foundation Library Release Notes | Build 23.0210
      The following release notes apply to Microvellum Foundation Library, Build 23.0210. Additions: • Added a new global variable “Hinge Offset From Edge” to provide easier control without needing to update the finished faces subassembly. • Added a sample ...
