How to Import Products using Database Management
NOTICE: The Import function of Database Management is a powerful tool that modifies data in the current configuration.  ALWAYS  back up your data before executing a data Import.
This simplified article provides a brief tutorial for importing Products using the Database Management Utility.
All records associated with the selected Product(s) are NOT transferred by default. Records such as Subassemblies and Materials should be selected independently.
Fig. 01 – Database Management Utility – Import Products
  1. Select IMPORT from Selected Source to Current Configuration > browse to the file location containing the MicrovellumFactory.sdf to be imported > select the MicrovellumFactory.sdf.
  2. Select the Products tab.
  3. The middle panel is populated with data from the selected database. Select the Product(s) to be imported from this central panel.
  4. When pulling from an archival database, chances are not everything in the external database needs to be imported. The middle panel in the image above allows you to select only the items you wish to import. The items specified appear in the panel on the right. Items can be selected from multiple categories at once.
  5. Select Transfer.
Additional Options
When importing products, there are no Additional Options available.
Resolving Duplicates
When importing from a database that includes data duplicated from the Factory Database, like an archival database, the Resolve Duplicate Names window appears.
Fig. 02 – Resolve Duplicate Names
  4. Fig. 03 – New Name
When a product is imported, the software needs to be restarted before that Product can be selected from the Draw Products menu.
