How to Install a Library Expansion
This article details the process of importing a library
expansion into your Foundation Library.
Before continuing, make sure that
the expansion build number matches your Foundation library build number.
The Database Management Import tool modifies
a large section of data in your current configuration. You should back up your
data before importing any library expansion. You can find more information on
Database Management Utilities here.
1. Locate the
library expansion .zip file you would like to import into your Foundation library.
Open the zip file and extract the SDF file to a location of your choosing.
2. Launch
Microvellum Toolbox and select Options from the Toolbox Setup drop-down menu to
open the Configuration Editor interface. To access the Database Utilities, select
the Utilities tab on the far right of the interface and click the Database
Management button.
3. From the
Database Management interface, select the IMPORT radio button in the bottom
left corner to open the files on your computer. Locate the expansion SDF file
you previously extracted and click import. A notification will appear asking if
you want to select all Database Records from the file. Click, yes.
4. Click
Transfer in the bottom right corner to start the import. When prompted, click
OK to end the import process. If you have additional expansions to import, you
may repeat this process or exit the Database Utilities.
- If the import process was successful, you will see the new library expansion category and products available within the Draw Products interface inside the Toolbox palette.
If you are interested in acquiring a
library expansion and need additional details, please contact your Account
Manager. Your Account Manager’s name and contact information can be found in
your Toolbox/Help/About Microvellum interface.
Related Articles
How to Install the Foundation Library
This article provides details on the process of installing the Microvellum Foundation Library. Install 1. Click the Imperial or Metric download link found within the Current Build section of the Foundation Library Download (All Regions) knowledge ...
How to Install a Foundation Library Update
This article includes details on the purpose of a Foundation Library update and how to perform an update. To perform a Foundation Library Update in the Toolbox, you must have Toolbox build 22.1.729.641 or newer to have the Library Update Utility ...
Preparing Your Computer to Install Toolbox
This tutorial demonstrates the steps recommend prior to installing Microvellum Toolbox and Toolbox AC (AutoCAD Companion). Prior to installing an update, we advise backing up your current data before initiating the process detailed below. Due to ...
Preparing to Install Microvellum Software
The steps listed below should be finished before installing any Microvellum software, including Toolbox, Production, and also before installing a program update. Following these pre-installation steps will prevent "error code 1603" & “Cannot find ...
Integration Guide for the Face Frame Expansion
Below you will find the file download for Microvellum's Face Frame Integration Guide. Form fields are pre-filled with Imperial library default values. This integration guide contains details and settings for Microvellum’s Foundation Library - ...
Recent Articles
Toolbox Release Notes | Build 23.1.0921.641
The following release notes apply to Toolbox build 23.1.0921.641 Cumulative Library Updates Fix Figure 1: Cumulative Update issue. There was a bug noted by users while attempting to download the Foundation Library’s phase 1 cumulative update and ...
Microvellum Foundation Library Release Notes | Build 23.0919
Additions Added new product Master Double Sided Cabinet. Added “Horizontal Handles Centered” global option to all doors. This is available for all tab pulls, handles, and knobs. Added a new DRAWRECTANGLE 2D plan token to the door subassemblies. This ...
My Cases: Case Details
Once you've logged into the Client Portal and navigated to the My Cases area, simply click on the case title to access the case details page. Here, you can thoroughly review the case description, append additional comments, upload attachments, and ...
My Cases: Overview
Once you've logged into the Client Portal, accessing your support cases is a breeze. You can simply click on the "My Cases" icon in the flyout menu or choose the "View Cases" button conveniently placed on the Welcome page. Inside this section, you'll ...
Uploading Attachments to Support Cases
Support case attachments are files or documents attached to a support case or ticket, serving the purpose of providing additional information, context, or evidence relevant to the reported issue. These attachments can encompass a wide range of file ...
