How to Install Microvellum AC (AutoCAD Companion)
- Right-click on the Setup.exe file and select “Run as administrator”.
- Observe the initial installation window (as seen above) and select “Continue”.
- Read and accept the license agreement and select “Continue”.
- Observe the release notes screen and select “Continue”.
- Configure the desired destination folder and select “Continue”.
- Configure the Microvellum installation to match the desired version of AutoCAD. For Microvellum Standard 2025 select “AutoCAD_English_2025_X64” and select “Continue”.
- Observe a notification upon successful installation.
- Microvellum Standard will be available via the AutoCAD version specified in step 6.
