New Client Registrations
Please provide the email address at which you wish to receive communications related to your support cases. If you are a new Microvellum client registering for the first time, it is highly recommended (required) to use your official work-issued email address. This ensures the accurate assignment of your support cases to your company's account.
Existing Client Registrations
To streamline the process, please note that if you've used Microvellum's support ticketing system or the Microvellum Knowledge Network (MVKN) before, you will still be required to create a new Portal account. To ensure seamless access to your active support tickets and case history, be sure to use the same email address you previously utilized for MVKN. It's crucial to maintain this email consistency, as using a different email address will result in your account not being associated with your company, thereby denying you access to your support cases.
If you are an existing client with an active MVKN account, you should have already received an email containing instructions on how to access the new Cases Portal. In case you cannot find this email, please check your spam or junk email folders as it may have been flagged by your email system.Choose a Password
Choose a password to secure your login. Be sure that it meets the following requirements: at least 9 characters, one capital letter, one lowercase letter, one number, and one special character.
For existing clients, while we highly recommend you use the same password you have established for the MVKN login, it is not required that you do so.
Password Your Reset
In the event you cannot remember your password, you can always reset it. Just enter the email address you used to create your account and you will be emailed instructions to reset your password.
