Library Data Help Documents
Several advancements have been made to our product libraries. Below is a list of topics that have a matching document attached to this article.
  1. Island Starter Details
  2. Global Workbook Column Numbers
  3. Global Workbook Spreadsheet Interface Layout Explanation
  4. Library Data Codes
  5. MDF Door Library for Machining
  6. Workbooks in MV
  7. Prompt Drawing Token Tabs 2-5-18
  8. Center Panel Y Origin Formula Layout 3-6-18
  9. Door Documentation - 048 Library 2-26-18
  10. Use Last Value Code Assignments 3-12-18
  11. Special MV System Prompts
  12. Updated Token Parameters 7-6-18
  13. Material Pointers Explained
  14. Associative Hardware Tutorial
  15. Material Spreadsheet Columns
  16. Special Hidden Prompts for Extruded Products
    • Hardware from Machine Tokens (Overview)
      Microvellum software can now accumulate and populate hardware to the work order database based on specific machine tokens. It is one of the useful new Microvellum features supported in build 15.6.2201 or greater. This new ability works only with the ...
    • Microvellum Flatshot Token (Reference)
      The purpose of this article is to document the parameters of the Microvellum Flatshot Tokens available as of build 15.6. Elsewhere in the Microvellum Knowledge Base, you will find articles and tutorials giving an overview of the token, how to access ...
    • Overview: Material Pointers
      The material of a part is determined by the Material Name property associated with the part. The image below shows a Base Back part within a product and the material that is currently assigned to that part.  Fig. 1 – Base Back currently has the ...
    • Working in the Prompts Tab
      Working in the Prompts Tab To edit a prompt (whether at the product or subassembly level), select a prompt from the list. With the Prompt Values tab selected, you will be allowed to edit the Value, Help Text, Combo Box Value, Mirrored Value, Picture ...
    • Overview: Material Wizard Prompts
      In our effort to reduce the number of separate cut part materials, edgeband materials, and hardware materials, Microvellum has created what we refer to as formula-driven materials. The interface for user interaction between these materials and the ...
    • Microvellum Foundation Library Release Notes | Build 22.0520
      The following release notes apply to Microvellum Foundation Library, Build 22.0520 Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial. Additions: ...
    • The Range Hood - Add-on
      About the Library Add-on This is a “Master” Range Hood product capable of being used as is or saved back to the library numerous times in unlimited number of different combinations.  This Library Add-on is compatible with the Foundation Library. This ...
    • Toolbox Release Notes | Build 22.1.0406.641
      The following Release Notes apply to Toolbox Build 22.1.0406.641 Database Management Resolutions: Resolved an issue that caused template level projects to be deleted when deleting a seemingly “empty” category (this was caused by a mix-up in the ...
    • Microvellum Foundation Library Release Notes | Build 22.0407
      The following release notes apply to Microvellum Foundation Library, Build 22.0407 Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial. Additions: ...
    • Toolbox Release Notes | Build 22.1.0325.641
      The following Release Notes apply to Toolbox Build 22.1.0325.641 Toolfile Resolutions: Resolved an issue in certain post names where the pecking number was not working. Resolved an issue in certain post names where some face 6 machining was falling ...
