This article highlights special prompts that Microvellum’s software specifically looks for to trigger certain events and features. DATABASE PROMPTS It is critical the three product/subassembly prompts below remain intact and unaltered in their ...
The purpose of this article is to provide insight of the Global Variables when interacting inside the Toolbox Interface. How to Access the Global Variables With Toolbox open, click "Toolbox Setup > Project Specification Groups." Select the desired ...
Working in the Prompts Tab To edit a prompt (whether at the product or subassembly level), select a prompt from the list. With the Prompt Values tab selected, you will be allowed to edit the Value, Help Text, Combo Box Value, Mirrored Value, Picture ...
To begin modifying the components tied to a specification group collection, you must select a specification group collection first, indicated by the green checkmark. By clicking on the icons directly above the left section, you can modify the ...
We are working to improve the usability of Microvellum software. Some of our Users have asked for the ability to edit multiple prompt values from the drawing. This boosts the speed at which the program may be used since the prompts do not require ...
