Material Prompt Category Filter
A Material Prompts Category Filter can be applied to prompt control types 7, 8, and 9. In the prompt tab of Edit Design Data and Library Designer, the Combo Box List column has been repurposed and renamed Control Type Data. For combo box control types, the Control Type Data column will still be used for Combo Box List data. However, for prompt control types 7, 8, and 9, Control Type Data can now be used to add a filter to material categories in the material selection UI.
Enter the keywords for the filter, separated by commas, into the Control Data Type column. Each keyword is added to an include list, meaning that the category must contain that keyword in order to be displayed. If the keyword starts with a minus sign, it is added to the exclude list, meaning the category will not be displayed if it contains that keyword. All parent and child categories of a filtered category will be displayed. If a child category contains an excluded keyword it will not be displayed in the tree view.
For instance, say you wanted to show all Pulls except for the Glass subcategory. You would enter "Pulls, -Glass" into the
Control Type Data column of the prompt.
The interface also contains a toggle button to turn off the filter and display all categories in the tree view.
Related Articles
Special Microvellum System Prompts
This article highlights special prompts that Microvellum’s software specifically looks for to trigger certain events and features. DATABASE PROMPTS It is critical the three product/subassembly prompts below remain intact and unaltered in their ...
Working in the Prompts Tab
Working in the Prompts Tab To edit a prompt (whether at the product or subassembly level), select a prompt from the list. With the Prompt Values tab selected, you will be allowed to edit the Value, Help Text, Combo Box Value, Mirrored Value, Picture ...
Overview: Material Wizard Prompts
In our effort to reduce the number of separate cut part materials, edgeband materials, and hardware materials, Microvellum has created what we refer to as formula-driven materials. The interface for user interaction between these materials and the ...
Tutorial 2: Passing Prompt Information Between Workbooks (Face Frames)
This tutorial shows you how to configure a subassembly to pass information between the L! workbook (local prompts), and the S! workbook (subassemblies). The article: "Overview: Passing Prompt Information Between Workbooks" discusses how the new ...
Working Within the Prompts Tab
The Prompts tab is where all the prompts that are visible within the Product Prompts are located. The Prompts tab also contains hidden prompts. Hidden prompts begin after the first blank row in the Defined Name column. Prompt is another term for a ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0322
Additions Added the Master Angled Ends Cabinet. Added a Global prompt, "Hinge Plate Offset From Front" for easier control. Added “Double Division” option to Horizontal Designer Cabinets, 3 Door Cabinets, and other similar products. Added a new ...
Common Floating License Connectivity Issues
This document lists common issues reported by users regarding the topic of Microvellum’s Floating License Activation (FLA) and the connectivity required for FLA to function. Firewall Blocking Activation of Floating License Some users have had an ...
