Microvellum Foundation Library Release Notes | Build 20.1201
The following release notes apply to Microvellum Foundation Library, Build 20.1201
Please make sure you are selecting the correct specification group when drawing products. One is for metric and the other is imperial.
Additions:
- Added Master Transition Angle Cabinet
- Added Master Diagonal Angle Cabinet
- Added Master Vertical Designer Cabinet
- Added Inner Drawer Subassembly
- Added Angled Adjustable Legs Subassembly
- Added Angled Shelf Adj Subassembly
- Added Angled Shelf Fixed Subassembly
- Added Angled Vertical Splitter Component Subassembly
- Added Diagonal Angled Adjustable Legs Subassembly
- Added Diagonal Angled Shelf Adj Subassembly
- Added Diagonal Angled Shelf Fixed Subassembly
- Added Diagonal Angled Vertical Splitter Component Subassembly
- Added Diagonal Angled Countertop Subassembly
- Added Notched Toe Kick Subassembly for Standard Master Cabinets
- Added Notched Toe Kick Subassembly for Master Corner Cabinets
- Added Notched Toe Kick Subassembly for Master Transition Angle Cabinets
- Added Notched Toe Kick Subassembly for Master Diagonal Angle Cabinets
- Added Back Corner Chamfer and Notch Options to the Corner Cabinet
- Added Product Prompt Images to products.
- Added Machine Token Names to Tokens that are turned off.
- Added Product Name to all master cabinets.
- Added Hinge Plate definition.
- Added Angled hinges for both positive and negative angles.
Modifications:
- Modified Product Tab structure.
Resolutions:
- Resolved a typo in the prompt "Blind Corner Hinger Clearance."
- Resolved an issue where Shadow Line Types "L Shape Solid Rail" and "Shadow Line with Backing Rail" did not draw correctly due to name errors in the subassembly.
- Resolved an issue where Double_Drawer_Handles and Double_Drawer_Handle_Distiance_Apart prompts in the Finished Faces subassembly did not reference local prompts.
- Resolved an issue where the Double_Drawer_Handle_Distance_Apart prompt did not become visible when Face_Options was set to "Drawers."
- Resolved an issue where the Cabinet Modification Options tab did not appear when the Cabinet Notch Center was active.
- Resolved an issue where Right Thick Back moved wrong when adjusting Cabinet Modification Center Distance to Center prompt.
- Resolved an issue where the Drop-Down Door handle was on the bottom of the door.
- Resolved an issue where Wrapped Batton width was hardcoded metric.
- Resolved an issue where the Master 2 Bay Horizontal Cabinet's width was hardcoded metric.
