Resolved an issue with the door-drawer cabinet, where the Drawer Stretcher options were hidden.
Resolved an issue with countertop appliances drawing with the Add countertop prompt set to 0.
Resolved an issue where changing door type did not auto-populate the door style.
Resolved an issue where changing Applied End Type did not auto-populate the Applied End Style.
Resolved an issue in corner cabinets when Right Swing is selected. Incorrect X origin for the left door.
Resolved an issue in corner cabinets when the Carcase Radius prompt is set to zero (breaks PLINE in Top/Bottom and shelves).
Resolved an issue with the top hinge moving down the facia panel height when using a top facia panel in the MV Profiled Doors and Solid Wood Doors.
Resolved an issue with the runner holes not corresponding to the correct slide length in the wood drawer box. Slide holes were looking at "Depth-Back_Space_Requirement", should be looking at "Slide_Length".
Resolved an issue with the right Dado on the front stretcher when selecting "Vertical Front Rail".
Resolved an issue with Blum Legrabox being hard locked to an inner drawer.
Resolved issue with face 6 machining on the divisions in the Inner drawer subassembly insert.
Resolved an issue with overlapping prompt in the global for dowel target spacing causing the target spacing to come out as the dowel diameter for custom spacing.
Resolved an issue with door bumpers attaching to the tops and bottoms in corner cabinets.
