Resolved an issue with Grass Dynapro drawers referencing the lookup tables.
- Resolved an issue with corner Shelf Adj Subassembly having unnecessary face 5 and 6 machining.
Resolved an issue with some variables in backs not referencing the back capture amounts.
Resolved an issue with L!Flatshot_Parts_List does not reference G!Flatshot_Parts_List
Resolved an issue with several part sizes in the Cabinet Modifications when using dado construction.
Resolved an issue with several local flatshot tokens not referencing the global.
Resolved an issue with external defined name references in the name manager of several drawer box subassemblies.
Resolved an issue with the Top-Drawer Front Height Prompt on Door-Drawer Cabinets, this prompt is Control Type 10 not allowing the user to manually change the value. Changed to a 1.
Resolved an issue with the front panel origin in the Upper Undermount Rangehood cabinet when using full inset doors.
Resolved an issue with the top being the wrong size when using full inset doors in the upper range hood cabinet.
Resolved an issue with the dowel machining still drilling even with "No Machining" set for hinge cups in the global file.
