Microvellum Foundation Library Release Notes | Build 21.1115
The following release notes apply to Microvellum Foundation Library, Build 21.1115
Additions:
Added new prompt images for the Vertical and Horizontal Opening Splitter Components.
Added the prompt "Ramp_Associative_Dado" to the global file.
Added hardware drawing for the Italiana Libra H1 Wall hanger. and have also added it to the Suspension Brackets subassembly.
Added Global "G!Finish_Label_Options" This controls whether the Finish label comes from the Wizard or the material being use. If it is from the material this will come from the material comments.
Added the ability to change the angle of the back chamfered back corner on all corner cabinets.
Modifications:
Cleaned up the placement of the dynamic product images when turning off views.
Revamped the Diagonal Angle cabinets.
Resolutions:
Resolved an issue with the placement of the tip_on hardware on doors, this has also been renamed to Push Catch.
Resolved an issue with the G!Shelf_Standard_Tool being set as a default of 0.
Resolved an issue with the Tall 2 Door Broom Cabinet, where the shelves were activating on both sides of the division when selecting Shelves_Right.
Resolved an issue with the G!Default_Top_Drawer_Front_Height. It was not referencing the Wizard.
Resolved an issue with the Pigeonhole subassembly where the halving joints on the shelves were not lining up with the divisions when using Dado construction.
Resolved an issue with the Wood Drawer box, it was not looking at the Global "G!Default_Wood_Drawer_Slide" as default.
Resolved several hole drilling spacing issues with the Hettich hinges.
Resolved an issue with the Base 2 Door 2 Drawer Cabinet, where the drawer boxes were the incorrect width when having different side thicknesses.
Resolved an issue with the cam tokens on the left and right side of top not matching bottoms. This was causing the spacings between cams to be different in some cases.
Resolved an issue with the "Corner Notched Toe Kick" subassembly. The Prompts "Amount to Expend Left Toe Kick" and "Amount To extend Right Toe Kick" were incorrectly named.
Resolved an issue with the edging on the top and bottom edges on thick backs not referencing the global top and bottom edges finished prompts.
Resolved an issue in the blind corner cabinets, when using a blind corner hinge with on blind corner facia. The Blind corner panel was the incorrect size, also the hinge plates were not associating with the blind panel.
Resolved an issue with a number of drawer subassemblies, the depth of the right slid holes were looking at the same formula as the left slide holes. Needed to look at the "Full_Depth_Runner_Holes_Right".
Resolved an issue in the Master 2 Bay Vertical Cabinet, where the material selection for adj and fixed shelves were looking at an incorrect formula to change to a wide span material.
Resolved an issue with the Wine Rack Trellis subassembly when using the Lattice option in Imperial. The Lattice size was looking at incorrect formulas needed to use the UCN conversion formula.
Resolved an issue where the "Countertop with Miters" subassembly was not referencing the Edge details from the local product.
Resolved an issue with the corner cabinets not considering the "Inset_Top_and_Bottom" prompt in the setback of the tops and bottoms.
Resolved an issue in the "Shadow Rail" subassembly where the Vertical route on the left side cut-out was set to draw only.
Resolved an issue with the machining on the Transition Cabinets where the pattens were not allowing for the angle depth when using custom spacing.
Resolved an issue with the lookup table in the "Wood Drawer Box" subassembly when using the Hettich Quadro V6 runners. There was a name error when looking up the table.
Resolved an issue with the placement of the parts list added to the iso view in the dynamic product image when using imperial. the x and y origins were hard locked to metric values.
Resolved an issue where the Door Type prompt was hidden in the Upper 2 Door Microwave.
Resolved an issue with the Corner hinge on the finish faces not turning on the third, fourth, and fifth hinges when selected in the subassembly prompts.
Resolved an issue with the tall Wall oven cabinets, the cut-out in the sides for the shadow lines were not machining into the sides.
