Microvellum Foundation Library Release Notes | Build 22.0203
The following release notes apply to Microvellum Foundation Library, Build 22.0203
Additions:
Added up to 20 groove routes for the MV Profile door. This has
doubled the number of grooves.
Added additional Part Label reports.
Resolutions:
Resolved an issue with the vertical routes
not offsetting correctly in cabinet modifications when using applied ends and
Selecting "G!Include_Applied_Ends_In_Cabinet_Width".
Resolved an issue with the Open-end cabinets
where there was no machining into the left side when selecting Left Hand
prompt.
Resolved an issue with the fixed shelf
subassembly where Par 5 of the Dado token. The thickness references were looking
at G!Dado_Clearance when it should be G!Dado_Groove_Width.
Resolved an issue with the hinge plate on lift-up
doors, it was looking at the Thickness left side instead of the Thickness top for
the offset of the plate.
Resolved an issue with the "Richelieu
Optimiz-R" drawer system when using any Region other than CA, the
drawer box would not draw.
Resolved an issue with the Eq formula
calculating the bay width in the “Material Trolly” products incorrectly.
